OK since Castle is done I had to find a new ESC and picked the 120amp for my little Miss Budweiser and the 300amp unit for my PT45. Both are holding back power and I have gone through the programs many many times with the esc, transmitter and receivers. The Miss Bud will run at 75% power but works perfect other than that and the 300amp version in the PT is off by 10mph and 2,000 rpm . Anyone run into this? Can a controller be not as "powerful" from one brand to another?
Swordfish 300 and 120
hello Gary
this problem is "normaly" solved with the latest firmware you can download on Hifei web site
i had same behaviour .............. 8 month ago, new firmware solved this
problem occur only with Spektrum radio
one solution is to set throttle to 80% , then calibrate radio and Esc
when done, set throttle to 100%
