I am having a problem uploading the Swordfish 300 amp esc disc to my computers. I have four in the house and they all say I need a 64 bit of DP inst.exe. Any ideas? My sons computer will see the disc and show the manuel {directions} but will not load the program part.My other computers will not even show there is a disc in it. Any ideas? I do have windows 7 as well.Thanks.
software upload for swordfish 300 esc
It's not that you can't install on your C drive, just don't install it in the default "Programs (x86)" folder. Install it most anywhere else, say in your RC Boat folder. You will still get the "64 bit of DP inst.exe" message so once the install is complete go into the "HiFei v4.x" and run the application "CP210xVCPInstaller_x64".Comment
buy yourselves a 4Gb USB drive .. once plugged in it has it's own drive letter assigned ..
install the software there....
btw .. USB2.0 drives are native at 32bitWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Got it all working but do not like this controller at all. Motor sounds very strained when first hiting the throttle, power is down across the board, shows spikes of 508 amps when normally around 350-375,according to castle readings, no reverse which is a real pain sometimes trying to line her up and overall a quirky unit. My Caste 240 units where Sooo much smother, easyer to work with and overall just better. If they only could handle more power when castle came out with them. Oh well.PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mphComment
go figure.
Their plug and play ability saw many returned in little black chunks.. however when properly set they were indeed great.
Were Castle logging buffered mean averages, or actuals ....... the hifei logs spikes and all ..... you can edit the log to follow voltage drifts under load super handy info
reverse ? oh my ... yes I see a few benefits, but hardly worthy the applause.
stick with it .. when you have the setup right it will truly impress ......Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
