Help programming Swordfish Pro 220 ESC
  • Jlov
    • Nov 2013
    • 825
    Can someone please tell me how to program this Swordfish 220 Pro ESC to my Leopard 4074 2150kv. I have the program box and I am running 2 2S 5000mah in series. Using a S/B Y547 prop. Someone did my last ESC and I am unsure what all the settings need to be. Thx Jeff
  • Rocstar
    Joel Mertz
    • Jun 2012
    • 1509
    I have a manual uploaded here. It shows all the parameters.
    • Jlov
      • Nov 2013
      • 825
      Ok thx that helped. I used Tx and Got prop turning now. But I thought there was more specific settings like timing and few others that I use the program box to set.....Thx Jeff
      • Rocstar
        Joel Mertz
        • Jun 2012
        • 1509
        Set the start up type to "Soft Start" and I think your motor is a Y wind, so 10-14° timing.
        • Jlov
          • Nov 2013
          • 825
          Ok thanks. I had it different. Just changed it to soft start and I'll try it at 12* first. Thx Jeff
          • Jlov
            • Nov 2013
            • 825
            Why the soft start and not standard or fast?
            • tlandauer
              • 5666
              Jeff, in case you missed this thread:http://forums.offshoreelectrics.com/...122#post551122
              Read the last few posts!
              • siberianhusky
                • Dec 2009
                • 2187
                I have no idea why soft start, I'd be interested in knowing the reasons behind this, never set mine to that and I've abused the crap out of mine no problems with the regular start.
                Happy to change it if there is a valid reason behind the change, never to old to learn something.
                  • 7673
                  If you don't do soft start it will be jumpy when guiding it in to shore/dock. Ask me how I know....
                  For some reason this series does that.
                  It is also easier on drivetrain.
                  • siberianhusky
                    • Dec 2009
                    • 2187
                    Strange! Maybe it's the way I bring in my boats, not something that I've noticed at all, I still use the old nitro technique for bringing my boats in. Old habits die hard.
                    If that's it I'll stick with the regular start. If it ain't broke don't fix it.
                    • Jlov
                      • Nov 2013
                      • 825
                      Ok so the disadvantage is that it's a little jumpy coming in which doesn't matter as I have the LVC cutoff set to soft anyway. But what is the advantage to running it in standard start up. Does it accelerate faster and smoother? Thx Jeff
                      • Rocstar
                        Joel Mertz
                        • Jun 2012
                        • 1509
                        My experience is the "Soft Start" results in smoother acceleration.
                        • Jlov
                          • Nov 2013
                          • 825
                          Ok thx Rocstar soft start it is.....
                          • Jlov
                            • Nov 2013
                            • 825
                            One more programming question. I have the LVC set to 2 cells as I'm running 2s lipos. Do I set the next setting which is LVC per cell to 2.8v ? Thx Jeff
                            • tlandauer
                              • 5666
                              Set @ 3.2/cell. 2.8 is too low and will damage the cells .
