I'm having a problem getting my new swordfish 200 pro to work. It's paired with a leopard 4082 1600 and a 6s battery pack which are both new as well. When I switch the esc on, there is an initial two-tone beep followed by seven additional beeps. With these additional beeps, the motor makes a slight twitch. I've tried altering the esc parameters in terms of changing the lvc voltage, motor timing, etc. The esc parameters At the moment are: lvc is set to 6 cells, lvc per cells is at 3.2v, brake type is set to no, timing is at 10 degrees, cut off type is set to hard, start type is set to standard, pwm is set to 8 kHz. I also connected a known good motor to the esc to disqualify the motor. In the interest of full disclosure the radio is an older fm radio and I'm using 4 aa batteries to power the reciever (for testing purposes). I've used this radio for years without any issues but could this older radio not be compatible with this esc?? Any input would be greatly appreciated.
Problems setting up a new swordfish 200 pro.
