i got a traxxas XO-1 and will take the receiver and transmitter to test it on the esc“s, there is definetly something wrong, 6 months im searching for a reason why this crap wont work, everythign done what is in my possibility, maybe tomorrow it works ;(
ESC QUESTION, Hifei Swordfish PLUS 200 amp
with the last drve of my zonda i get only 34 km/h, lvc was off, 39mm props on 2075 lv dwind sss 37mm motors with 5s, thats really not ok ;(Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
so, i tryd today 3 different transmitters, 1,5 hours working on this and i cant set the esc“s for 100% throttle, i tryd everything that is possible, still not solved, i writed a mail to hifei, lets see what they say to this.Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
When you use USB it will show the throttle range setting. if this is more than 700us it is 100%....
China has Chinese New Year holidays now.. every one is closed until maybe 20th !
This is most strange
1. does your Rx use power from esc ? I would try outside Rx battery ( use USB to turn of Rx power from esc )
I hear the esc play tone for 4 cells in video #1
You have set by USB to 4cell ?
Set by USB the timing for medium.
very unusual for 2x esc same fault..
cheers
WWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
HAHAHA, yesterday i writed and workd on the boat from 22 pm till 7 am, and yes i was here and writed everythinggood night, hahaha, i hope you find a answer :p
drwayne, got a screenshot for you.
you can show me yours? or someone others can show me that he really get 100% throttle?Attached FilesZonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
SOLVED, i get it, finally, i needet to set my spektrum DX2.0 on 75% throttle, then i Setted up the Esc: 3 beeps when plugin in with holding Throttle Max forward, then comes 1 beep, pause, 2. beep, pause, 3. beep (release).
after that, i give full throttle to record the data for the data logger, with about 20% throttle i change on the transmitter from 75% to 125%, and then i get the 100% throttle.
oh man, that was a hard job, about 3 months working on this -.- (not all the time, every week 2-3 times)
screen 1 = Esc on the Right side
screen 2 = Esc on the left side
how you can see the motors are working a little bit different, shoud i see that when driving in water?Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100cComment
