Swordfish data logging
  • worriedsick4u
    • Dec 2011
    • 693
    I have the new version 240HV and I can't get the data logging page to open when I click on it. Anyone else have this problem?
  • steveo
    • 1454
    the way i understand it its a raw file and i had to down load a program free it should explain it in maybe the help section and even bring u to a location to down load it, as i am not 100% my wife helped me, the esc is only supported by a few os systems and i did not have that type to run it so i think thats why i had trouble- shoot me a pm tomorrow and i will help u out, other than that its real easy to use, i have the 200 and have used to log my revolt30 with ul-1 motor
    • worriedsick4u
      • Dec 2011
      • 693
      Thanks Bro. I have the program downloaded. I use it to set up my ESC. I just can't get it to download the frigging data. I'll shoot you a pm later today. I think I'm gonna hit the local lake this weekend. Maybe we can meet up?
      • kevinpratt823
        • Aug 2012
        • 1361
        I am in the same boat, running windows XP. Did you get this working?
        I beleive I have my permissions settings open, but I'm no computer genius, and my hard drive only appears to have one location(C:), not sure where else to go as these are the 2 issues a search came up with.
        I can change parameters, but can't open the data logging..........
        My private off road rc track
        https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
        • worriedsick4u
          • Dec 2011
          • 693
          I gave up trying. If you figure it out, let me know.
          • kevinpratt823
            • Aug 2012
            • 1361
            Will do, somebody out here must have figured it out..................???????
            • keithbradley
              • 3663
              Uninstall, re-download but do not save to drive C. Just save it to an arbitrary space, like "documents".
              If it doesn't work, let me know.
              www.keithbradleyboats.com
              • kevinpratt823
                • Aug 2012
                • 1361
                Tried this, still unable to access logging and records............
                It still goes under C:documents and settings when I put it into "My Documents" not sure if that is what you meant......
                It still goe under a seperate folder that acessed seperately from the C: (local drive) icon under My Computer.
                • keithbradley
                  • 3663
                  Kpratt is your ESC a 240 or 300?
                  Worriedsick, where did you get your 240HV?
                  I don't think Steve carries a 240 that datalogs...are you sure you have an ESC with a datalogger?
                  EDIT:
                  To clarify, the "Pro" Swordfish ESCs do not have dataloggers, only the "Pro+"
                  • kevinpratt823
                    • Aug 2012
                    • 1361
                    Wow Keith, what a profound revelation, you are a genius. Mine is a 240pro hv, and on further inspection, data logging is not listed as a feature in the description on the OSE store.
                    I guess I was just under the impression that all the new versions had it.
                    I bought it as a quick replacement for the Castle 200hv that turned into a brownie last week, guess I didn't read closely enough.
                    Kind of a bummer that with all the new versions, this one didn't get data logging........
                    Edit: Mine is a 240hv Pro, apparently it is the Pro Plus that has the data logging.....
                    • worriedsick4u
                      • Dec 2011
                      • 693
                      Mine is the pro plus. So frustrating I quit trying.
                      • keithbradley
                        • 3663
                        So yours has the gold label, correct?
                        When you attempt to upload the datalogs, you get a box that says "runtime error"?
                        Do as I mentioned earlier and re-download the program, installing it to another location. It will be simple and you will be reading data in just a few minutes.
                        • Jason4636
                          • Jun 2012
                          • 654
                          Keith is right, I kept getting the run time error. Uninstalled it, then reinstalled it in my documents. Everything works great
