Swordfish HV240 Question
  • scottw
    • Dec 2011
    • 49
    Hi
    Hope somebody can help me - i have a swordfish 240HV speedy that runs for approx 5 seconds then stops - I let the throdle go then it starts when I throdle up again
    Tryed 2 motors same thing happens
    Is this a programming thing????
    thanks in advance
    Scott
  • scottw
    • Dec 2011
    • 49
    Hi guys
    This ESC runs ok on 12s but when I run on 6s the motor cuts out after 5seconds
    Is this a setting on the ESC??
    Scott
      • 7673
      Do you have the instructions.I also have one in a boat I just bought,haven't played with it though.Just gonna run a couple of 200's and there were a couple of problem threads on them,kinda had me freaked.I downloaded the instructions and followed them and they run fine.Instructions are on OSE with the controller.
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        Very important to set to 12s and not auto detect same with 6s have to reprogram each time you change voltage
        Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
        "Follow someone's footsteps and you will always be a step behind"
        • JIM MARCUM
          • Jun 2011
          • 773
          You can get the manual & setup info at: http://www.astecmodels.co.uk/pdfs/Sw...240A%20ESC.pdf JIM
          JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
          • drwayne
            • May 2008
            • 2981
            If it runs ok on 12s but instantly dies on 6 .. chances are high the lvc is set for a 12S setup.
            Grab a program box and reset the lvc to suit, then try again.
            W
            • Marinetechal
              • Jan 2012
              • 26
              I had a Swordfish 200amp that did the same thing, thinking it was a radio issue tried a new transmitter and reciever, same deal. Tried all the programing options, same deal. Sent back under warranty, replacement did the same thing. Ran it one day and forgot to refit my cooler hose on the pickup, maxed out temp overload. Next time I used it still cutting out, then 3 mins on 6s it totally torched itself, nearly burnt the boat to waterline. Happy days as I only use Sea King 180's now, very happy with preformance!
              • sailr
                • Nov 2007
                • 6927
                The very first thing to set with most any ESC is the throttle travel! It varies between radio brands and the esc needs to know where these settings are! Turn the transmitter on and hold it at full throttle. Plug in your batteries. Wait for a beep(s) and then release the throttle trigger. A couple more beep(s) and the travel is set. THEN make all of your other programming changes.
                Mini Cat Racing USA
                www.minicatracingusa.com
