swordfish 120 burned up toaday
  • mikeochs
    • Nov 2011
    • 204
    Well not such a good day for me. Just got the miss geico ready last night. Runnin a leo 4074 1400kv swordfish 120, x442, 3s 40c 4000 x2 for 6s. I ran the first time for about 2 min and brought it back in, everything was nice and cool but i noticed a little had came in, from where i dont know. So anyways i dried it off and switched batteries and ran it for about 3 min at no more than half to 3/4 throttle and it all of a sudden dead in water. After abot 30 seconds of sitting there and try to see if it was going to go again a large flash happened and i thought it was going to burn down right there. I manage to get the rescue boat and get it in. Of course there was a bunch of black mess all over. The speed control obviously burned up, the batteries were ok though and rx was not working any more after I cleaned it all up. Im just curious to how this happened? I was not pushing it, The numbers are where they should be. Could it have been just a faulty part. And another thing, I had water in there again and more of it. Cant figure where it is coming from? Are these boats notorious for water? Any help would be appreciated. Do you think that speed control is to small?
  • Diesel6401
    Memento Vivere
    • 4204
    I have never been a fan of running esc's to there max voltage, another thing is not running the esc's bec past 4s. The swordfish esc's are great for the price, but the littlest bit of water will fry them. ( i had that happen, when I hit a turtle, split my hull and my esc got wet and fried my rx). Also running at less then full throttle is actually really terrible and hard on esc. Esc's like to be run full wide open throttle as much as possible. So you have a few factors that caused your failure imho..
    - running at max volt
    - running less then full throttle
    - running above 4s using bec
    * those 3 factors together increased the work load of your esc.
    At the end of the day a little bit of water may also have been the dimise of the esc.
    - Diesel's Youtube
    - Diesel's Fleet
    • mikeochs
      • Nov 2011
      • 204
      what would you suggest for a esc?
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        T 180.
        • mikeochs
          • Nov 2011
          • 204
          anyone have one for sale, evryone is out of them
          • jkr
            FE Addiction
            • 568
            Originally posted by LarrysDrifter
            T 180.
            + Run it w/o bec.
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              Check www.fightercatracing.com if OSE is out of stock.
              • Alexgar
                • Aug 2009
                • 3534
                sf 200 is another option. i love my sf120 and i filled the ends with sensor safe silicone and its been dunked 3 time and not fried for what its worth
                • Alexgar
                  • Aug 2009
                  • 3534
                  larry bens sold out also
                  • mikeochs
                    • Nov 2011
                    • 204
                    i was running a sf 120, do you think this is enough esc for my application. 4074 leopard 1400kv 3s 40c 4000 x2 and a x442. I was not even pushing it but if it got wet like diesel said, maybe it fried. It is very ugly and smelly
                    • martin
                      • 2887
                      120amp esc on 6s is a no no.
                      • lectriglide
                        • 538
                        Turnigy / Seaking 180. Steven has 49 in stock, and I believe he said in another post the new ones already have additional caps installed. Others have run 6s successfully with caps added.
                        http://www.offshoreelectrics.com/pro...er-seaking-180
                        • tiqueman
                          • Jul 2009
                          • 5669
                          I dont necessarily think you pulled too many amps?, but like Diesel said, running EVERYTHING at its max capacities, and probably the water as well, did it. Never run an ESCs bec over 4S. And, Ive been more convinced lately maybe to even stop running an ESCs bec at all.
                          If you get a 180, disconnect the BEC on it for 6S. I ran one a few weeks ago for a quick two pass trial to test something and ran 6S. 20 seconds after launch it stopped. internal BEC fried. I thought Id get away w/ it at least for 1 minute. Nope. I put an external bec in and on the next run everything stopped working. dead. Im starting to agree w/ a lot of our club guys, I wish they would stop offering becs in speedys.
                          • mikeochs
                            • Nov 2011
                            • 204
                            well lessoned learned i guess, costly one for sure. Now I had to get a new esc and a rx. So running a external bec is ok though or should i just use a rx pack?
                            • tiqueman
                              • Jul 2009
                              • 5669
                              Either one, external UBEC or RX pack. just be sure you disconnect the red wire out of the plug and cover it up.
