I bought a brand new swordfish 200 from ose for my traxxas Spartan. The problem is I run dual batteries in the boat and when I try to plug both of my turnigy 3s 5000 mah lipo's into my series connector then to the esc it won't do anything but if I just plug one battery straight into the esc without the series connector it comes on fine. Anyone ot any suggestions I already removed the wrapping and water proofed it so I can't send it back.
Swordfish 200 amp esc help!!!
sounds like boaterguy has hit it right.
if it works on 1 battery pack and then you go and plug in the series harness and nothing happens, sure sounds like a bad
harness to me.
take the harness off the esc set it on the table, get out the volt meter (hope you got one), hook up the batteries like you would
when you hook it up to the esc and check the output voltage at the esc end.
when you finish that and have disconnected the batteries, do a resistance check of the wiring on the harness. If you get a hi
resistance any where on it, then that is the culprit. (the harness)
this is a couple ways to check the harness out.
if it were mine (just my opinion) I would ditch the Deans harness and make one up using at least 5.5mm bullet connectors.Comment
IF you want less resistance, get rid of the Deans! Go to 5.5mm or bigger bullets.Mini Cat Racing USA
Update
So guys I feel stupid I figured out the problem and it is something I feel I should have checked first. The problem was one of my brand new lipo's (turnigy) from hobby king was bad and that's all it was. Had nothing to do with the esc or the series harness but I am upgrading to 6.0mm bullets and taking your advice with ditching the harness with the deans and building my own with thicker wire. Thanks for all the help now time to send my lipo back to hobby king USA.Comment
So guys I feel stupid I figured out the problem and it is something I feel I should have checked first. The problem was one of my brand new lipo's (turnigy) from hobby king was bad and that's all it was. Had nothing to do with the esc or the series harness but I am upgrading to 6.0mm bullets and taking your advice with ditching the harness with the deans and building my own with thicker wire. Thanks for all the help now time to send my lipo back to hobby king USA.Support US hobby suppliersComment
Is there a reason in this boat you need a harness to run series after you've gone to bullets? Do the batteries sit really far apart or something?Comment
So plug battery one neg into batt 2 pos. Then plug the wires accordingly into the esc. Typically use a female bullet on the positive lead on the battery and the male bullet on the negative battery lead. Now you've omitted use of a harnes... less resistance as you wished.Comment
