I am looking to up grade my fastec would a feigao 540 8xl and a hifei swordfish 120 make a good set up to run 4s and sometime 6s on. Some day I would like to put it in a Challenger 31". Would this work?
Feigao 540 8xl and Hifei swordfish 120 a good como?
IME anything over a 29" mono would be pushing it. That setup is proven in a 25" delta clone but in a OM29 it's close.If all of your wishes are granted, many of your dreams will be destroyed! -
I'm not saying the motor won't push it. I would go to at least a 150amp esc for the bigger boat so you can prop accordingly.If all of your wishes are granted, many of your dreams will be destroyed!Comment
8xl
I am running a Nemisis 8xl with an ETTI 150 IN A 26" H&M and the ESC barely gets warm. I had previously smoked a SEAKING and a TURNIGY 120 A in the same setup. You might want to spend more now and buy it only once. BGComment
Jabbo - "then what whould I need to bump it up to?"
The fastec is 27" long...............an XL motor will push it fine. I'd go 9XL for 4s if i were you. I have a 31" Villain nudging 40mph with a 12XL on 6s.................an XL will really move that boat out well!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
The turnigy 120a will run the XL motor just fine.....and up to 6s.......I own several, they are a great value............only$49 under my HK user login.
http://www.hobbyking.com/hobbyking/s...hless_Boat_ESCNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
If somebodys gonna sell me a 180 amp 360 burst for under a 100 dollars id be crazy not to get it it obvious that rite now the most success is being had with the turnigy/seaking 180s. if you worried about the amps I think you better go there. I mean I chose a turnigy hv 80 over a hv 100 because the 80 had more burst amp capability u have to really look at these specs but i bet the mystery 200 will hold up. I have a forcemax 60 in my atlas no problems. A elf hobbys 100 in my pak on a 6xl no problems. So its really hard to say but go for overkill get the 180 turnigy.Comment
