Etti 150 race Esc
  • EPower
    Banned
    • 391
    Etti 150 race Esc
    Hi well after burning my 3rd Etti Esc i have given up on this unit Frst time blew the caps added the extra caps bank to the second one, that one just stopped in the middle of the pond for no reason sent it back and mr Dee told me (Please be informed that the problem 150A ESC has been repaired!
    We have found your ESC has 12 x mosfets and 2 x IC were damaged)
    Got it back and on the second run same thing again stopped in the middle of the pond so i will not waste anymore of my money so far it owes me 600 nz$ (that includes a new lid for my MHZ Lizard Extreme that blew off the first time )
    I pulled the watercooling plate off it and i cannot figure out what it is supposed to cool ? can some one tell me?
    Cheers Adrian
  • NorthernBoater
    • 811
    It is cooling the ground plane on the board.
    • Rumdog
      • 6453
      where the heck are the mosfets?!
      • andym
        More Go Than Show Prop Co
        • 2406
        I too blew mine up with the cap board with well under 150 amp draw as well as the data logger and box that just did not work, threw the lot in the bin. For my 4s set ups it is back to the CC240 for me.
        When they go up the coating they use really gets burning!
        • EPower
          Banned
          • 391
          That exactly what i mean
          • Rumdog
            • 6453
            Unbelievable!
            • crabstick
              • Jul 2008
              • 954
              Ah Ballstrolley, when will someone make an ESC thats not a grenade! (that doesn't cost 1 squillion dollars)
              Matt.
              FE, Nitro and Gas racing in Auckland
              www.rcboats.co.nz
              • DISAR
                • Aug 2007
                • 1072
                I already blew two, probably one is in the post on the way back. Thanks Steven.
                Epower do you run your boats in sea water or pond? When running in sea water, no ESC can survive after immersion.
                I'm having positive results with the MGM Compro 25035 Zseries totally enclosed in a box made from epoxy and fibre. Expensive ESC but if you add the cost of the ones that I burnt and wasted time for water cooling-proofing cleaning etc...it is super.
                http://www.rcfastboats.com/
                • EPower
                  Banned
                  • 391
                  I have been looking at the MGM Compro 25035 E esc too i also like the new Schulze fut-l-24.150WK not sure witch one i will buy
                  What setup are you running with your MGM ?
                  • DISAR
                    • Aug 2007
                    • 1072
                    I tried it in:
                    a) DF 36" with a NEU 1515 1.5Y on 4s with X648, 5s with 645,646, 6s with custom 43mm
                    b) Mean Machine with NEU 1512 2D, 4s with 442
                    c) Mean machine with Align 600XL 4-5-6s with props 648-43mm
                    d) MM with Feigao 9XL 4s 445-645
                    The ESC survived in all tests where others had already died. I also use the black box with the USB link and see the amps on the pc. I do not know if 100% correct though.
                    The 24.150 has inferior specs, and so far the MGM is super.
                    • Himalaya
                      • Apr 2009
                      • 251
                      The plate cools the PCB's copper plane, it's where the MOSFETs were supposed to be soldered on, at the other side of the board. This could be a good engineering cos this allows a full-metal thermal path MOSFET-->soldering pad--> thermal vias--> copper plane--> aluminum plate--> water. Look at the "themal vias", 4 as a group, locate right underneath every MOSFET to tranfer heat to the copper plane. Unfortunately only half vias are connected to a copper plane, others have extremly tiny area to conduct with the aluminum plate, that could lead to some themal problems.
                      • Ub Hauled
                        • Aug 2007
                        • 3031
                        Cheers Adrian
                        Adrian, I feel your pain... I have bought and stuck by another brand of ESC that failed me one too many times, sometimes when I hooked up the batteries (hint). Anyway,
                        the FETs are sandwiched between the bottom board and the secondary board that you can see upon close inspection.They are mounted on the bottom board hens the heat transferring paste between the cooling plate and the bottom board... there should probably have been some more paste...
                        • EPower
                          Banned
                          • 391
                          Hey no worries i now know not to buy cheap over rated Etti esc and, i can't belive that his 200 Amp HV is selling for 430 Usd that's a joke really
                          Cheers
                          • DISAR
                            • Aug 2007
                            • 1072
                            I sent my burnt one to Steven and today I received a new one free of charge, that's a very good service.
                            Probably the ETTIs are very good for smaller boats (up to 30" max) and max 5s.
                            • Steven Vaccaro
                              • 8721
                              Cheers
                              Let me first say that I feel your pain and understand your frustration. I've been there and pulled the hair out of my head.
                              Let me explain how the Etti repairs are handled. ALL repair and warranty correspondence is done from the Customer to the Dealer. You cant go directly to Etti. So I know should know every problem that's been had with my customers and their problems with Etti controls. This is important, because it allows me to know the number of problems happening out there. I can say that its not as bad as you are making it out to be. Its rather quite small and on par or a bit better than the other esc's out there. I've literally sent less than 20 esc's back for repair or replacement. That number pails in comparison to the number that are sold and currently running around. Also if the Etti esc's were as bad as you think I wouldn't be selling the product. For two reasons. 1st I just pain dont want to sell junk. 2nd for the simple fact that I have to pay the shipping costs for returning these esc's. Both back and forth.
                              Could it possibly be your setup? What setup did you use? What batteries did you use and rating?
