castle on fire
  • 6ofthebest1
    • Jul 2009
    • 41
    castle on fire
    castle on fire
  • ozzie-crawl
    • Sep 2008
    • 2865
    wow thats nasty
    what was your setup when that happened
    • 6ofthebest1
      • Jul 2009
      • 41
      was running neu 1515 1.5y x646 on 6s2p need a new esc any ideas?? not castle
      • ozzie-crawl
        • Sep 2008
        • 2865
        what size esc was that
        • 6ofthebest1
          • Jul 2009
          • 41
          • ozzie-crawl
            • Sep 2008
            • 2865
            i cant really help as i havent ran a nue or a cc hydra hopfully some of the guys with experiance on these will chime in as there was somthing serious wrong for it to go up like that,then again seems to be a lot off cc pop tarts going off
            • 6ofthebest1
              • Jul 2009
              • 41
              i think you get what you pay for and i think anything maid in germany is the way to go shulze and yeg i think it is the way to go
              • ozzie-crawl
                • Sep 2008
                • 2865
                a lot of guys are getting good runs with the ettis
                • Raydee
                  • May 2007
                  • 1603
                  Is it a HV or LV? If its a LV Castle and many others have warned against running it at its max voltage. For my 6s boats I only run HV controllers and they have been running great. If its a HV then that is a different story.
                  Team Liquid Dash
                  • Gary
                    • Jan 2009
                    • 1105
                    My 240 just shorted out and went up in flames and started to cook the batteries at the same time.It was crazy to see smoke pouring out on a high speed run but not fun trying to rip the batts out and esc on fire . I had to submerge the boat under water while i pulled everything apart trying to save the hull.Talk about a nasty stench.LOL But...I beat on this esc for over a year real hard and pushed it to its limits 2 times a week straight.
                    H&M 1/8 Miss Bud 73 mph
                    Chris Craft 16 mph
                    • Steven Vaccaro
                      • 8721
                      What was the prop and boat size on that setup? Did you get many runs with that setup?
                      • 6ofthebest1
                        • Jul 2009
                        • 41
                        its a lv on 6s2p neu 1515 1.5y x646 the hull is a h and m drifter 41 inches long i had about 20 runs speeds around 100 -110kph
                        constant the only thing it can be is water got into the esc
                        • Raydee
                          • May 2007
                          • 1603
                          If you have water getting into your hull that can def be the reason. The other problem is running a LV on 6s is just begging for disaster. I know people have had some luck running the LV on 6s...heck I even did it for a few runs but for the most part running a ESC at its max voltage OR amp rating will almost always end the same way...charcoal. That is also a large hull for a small 1515 size motor so I imagine it working pretty hard to push a 41" hull, probably pulling some big amps too.
                          Team Liquid Dash
                          • Eyekandyboats
                            • 1921
                            try to NOT bunble your wires together with a zip tie~~
                            EYEKANDYGRAPHICS
                            www.rclipos.com
                            • bustitup
                              • Aug 2008
                              • 3071
                              Waaaaaaaay to big a hull for that motor ........I am surprised u got that many runs in
