Castle Barracuda 125
  • supafastsupra2
    • Aug 2008
    • 103
    anyone know how to program this esc? also for 4s think i can get away with using its BEC? Thanks in advance,
    SFS2
  • Raydee
    • May 2007
    • 1603
    I would get the Castle link to program it and I wouldn't run the internal BEC on 4s.
    Team Liquid Dash
    • supafastsupra2
      • Aug 2008
      • 103
      is it programmable via the castle link? I have one but i didnt think this old esc could be programmed via the link
      • Raydee
        • May 2007
        • 1603
        It should be...I programmed my 125 without a problem. Plug it in and it should without a problem BUT I would not update it to the latest firmware if it askes you to do so. My bud had three Cuda's completely quit after updating them and they all worked great before the new firmware was installed.
        Team Liquid Dash
        • supafastsupra2
          • Aug 2008
          • 103
          Damn thanks, i just went 1/04 but ill revert back to the one it had.
          • Raydee
            • May 2007
            • 1603
            If you already changed and its working fine then leave it on 1.04...there is more timing control and 1.03 had the timing values wrong.
            Team Liquid Dash
            • supafastsupra2
              • Aug 2008
              • 103
              timing values wrong? so what should i set it at if i want normal timing? i ask because the boat ran poorly today and im trying to iron out all possible issues. I ran it on 1P because i didnt have a harness made up yet but the timing can throw it off too
              • Raydee
                • May 2007
                • 1603
                What motor are you running?
                On 1.03 the timing is off and something like this
                low=16*
                normal=16*
                High=10*
                Extreme=16*
                Or something like that anyway.
                If you go to 1.04 then the timing will be the right values.
                Team Liquid Dash
                • Raydee
                  • May 2007
                  • 1603
                  Here is the post by Joe Ford from Castle expaining the 1.03 firmware problem.
                  http://forums.offshoreelectrics.com/...3&postcount=60
                  Team Liquid Dash
                  • racerr73
                    • Oct 2007
                    • 133
                    That link from Joe Ford states that is correct for the hydra controllers, the question is being asked for a barracuda controller.
                    • Raydee
                      • May 2007
                      • 1603
                      It has nothing to do with the controller, its the firmware that is in the controller. IF he has 1.03 in the cuda or the Hydra the timing is wrong.
                      Team Liquid Dash
                      • Darin Jordan
                        • 8332
                        I have several B125 ESCs, all updated to the new 1.04 firmware, and all working perfectly. Once you update them, go completely back through the setup process and everything should work fine...
                        Darin E. Jordan - Renton, WA
