Etti 150 getting hot, but why?
  • Jesse J
    Former scale FE racer
    • Aug 2008
    • 7198
    Dang, 56 is respectable. I have a pair of 5S waiting for me to get this ESC to chill out. Still not sure what to do....
    "Look good doin' it"
    See the fleet
    • NorthernBoater
      • 811
      Originally posted by Jesse J
      Is that a typo in the description where it says x656 should it say x646. Even an x646 seems like a lot. I run 4s on an 8XL with both either x640 and x636 and rarely see temps about 120-130. It looks like it is running fine in the video. What was the temperature of the pond? Warmer water will provide less cooling. Did you see water coming out of the exit nozel?
      • knpc
        • 566
        It usually runs 50-52mph, I just desided to air it out a bit and see what I could get out of it. I don't think I could go that speed with other boats in the water. It was with a 1515 1y 4s2p and an m445
        Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
        • Jesse J
          • Aug 2008
          • 7198
          yes typo, X646. I will try some smaller props, especially when I go for 5S. But even on 440 it was getting hot. Next try will be a K45 (lost my X and M445) time for another order from Egneg.
          and yes it was peeing fine.
          See the fleet
          • detox
            • Jun 2008
            • 2310
            I learned that caps can get veryhot...up to 195 degrees.
            • detox
              • Jun 2008
              • 2310
              Maybe you should also use the ETTI cap board.
              • Jesse J
                • Aug 2008
                • 7198
                I think that is very wise advice. Is it easy to add after the fact?
                See the fleet
                • Blackjack-sven
                  • Feb 2009
                  • 371
                  How long have you been running this setup?
                  HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
                  • Jesse J
                    • Aug 2008
                    • 7198
                    Well the motor mount came in the mail this afternoon and I was able to make three runs before dark (I know people have complained that my pond is too close - 3.7 min walk).
                    See the fleet
                    • NorthernBoater
                      • 811
                      Do you have two water pickups or is the line split between the motor and ESC?
                      • line6
                        • Aug 2008
                        • 478
                        The caps are 160? or is the hottest spot on the board 160? my hydra 120 comes in at caps around 140-160 board 120ish in my delta with a 8XL. I talked to the guys at castle and they said that those temps are fine. That i should really worry if the caps get over 200. but you say yours is shutting down. that dont sound good. how long till you get it back to shore? i have noticed the caps will cool off a lot faster then everything else.
                        • Blackjack-sven
                          • Feb 2009
                          • 371
                          #27
                          ***caution***..........................JUST A WARNING.........................***caution***
                          From my own experience, NEVER let the CC ESC's get above 180 as they will go .....I've had two of them go by "gearing up" my vehicles too much. I listened to the guys at CC as well and thats what happened to me.
                          • Chilli
                            • Jan 2008
                            • 3067
                            #28
                            I'm running the Etti 150 (no BEC) in a Titan 33. 1515 1y, X640. Also curious about board temp versus cap temp. Running 4s2p 4500, motor and batteries are in the 130's Large caps running mid 150's. Thats shooting right on one of the large caps with no shrink wrap. Board is in the 120s. Am I stressing the ESC?
                            Mike Chirillo
                            www.capitolrcmodelboats.com
                            • Blackjack-sven
                              • Feb 2009
                              • 371
                              #29
                              With the experience I have with CC, NO. I typically run at 160-165
                              • line6
                                • Aug 2008
                                • 478
                                #30
                                ya i thought the same thing i don't like them getting over 160. they told me that they are rated up to 225.
