Will these controllers handle a neu 1521 1.5 y in a blackjack 26? And if so what props do you recommend and what cell count?
Etti 150 and neu 1521 1.5y????
Tags: None
The 1521/1.5y is 1050kv. You will need around 6-7s ( which version of the etti you have? Only the 2-7s can handle it) and a prop. 50mm diameter to have good speed. This setup is not very ideal but might work (about 80-90 amps?).
I haven't tried it though. Small boat-huge motor with low KV-heavy batteries-big prop. It is like putting a 4000cc engine in a Smart car with 18" wheels. It won't last for very long.
Most probably, you will end up changing shaft to bigger one and to reinforce the hull also.Last edited by DISAR; 03-30-2009, 04:44 AM.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
