Badly discouraged
  • Slonoma406
    • Jun 2024
    • 1
    Badly discouraged
    Hi yes I have purchased the OSE Raider 150 Esc with Ec5 and I'm having a problem getting this thing to work I plug it in and all I get is continuous beep beep beep beep beep beep they were fast beeps but then they went to slow beeps small Pause in between I have put new battery ends on it more heavy duty I have reset my controller to factory specs I have learned to throttle end points I tried to anyway it won't do it I'm just at wit's end I don't know what I'm doing wrong or why I keep getting things messed up this is a third ESC in this boat that I can't get to work I tried a different motor same thing try different battery same thing try different receiver same thing I don't get it I'm about ready to pull my hair out and burn the boat down somebody please help I'm going crazy
  • NativePaul
    Greased Weasel
    • 2761
    I don't have that ESC so I can't give any definite specific help but I have used a lot of ESCs and there are some common beeps that are often used and could be what you are hearing.
    Lots of ESCs announce the cell count of the battery that has plugged in with a series of fast beeps, are you getting for instance 4 fast beeps with a 4s pack, or 6 fast beeps with a 6s pack?
    Continuous slow beeping is often an ESC not detecting a signal from the radio, is you transmitter bound to the receiver? Some radios do this with a button on the receiver and some with a bind plug that plugs into the receiver, you can test that by trying to move a servo, if the servo works then the radio is bound and you have a different problem.
    • Peter A
      • Sep 2012
      • 1489
      The constant beeps means either you have no rx signal or your throttle trim is not zeroed. Have you calibrated the throttle also? It sounds like the esc is searching.
      • Speed2
        • Jun 2023
        • 26
        Try hit reverse after you hear the beeps.
        The raider 150 does not allow you to give throttle with out giving reverse to arm it.
