Castle Phoenix Ice 200
  • Zondar
    • May 2015
    • 58
    Gents,
    What's the trick to using a Flysky FS-GT2E transmitter and FS 2 Ch.receiver, 3s lipo to power an inn-runner
    1100kv motor ? also trying a RadioLink RC4GS v3 with RL receiver. steering works ,throttle questionable.
    Help if you know,
    Zondar
    Traxxas Spartan, RCBB Zonda-R, Promarine MTR, Proboat IMP 31 v3, PB UL-19, Bonzai FE 47 Skater
  • NativePaul
    Greased Weasel
    • 2761
    I think you need a pixtix or similar to run an air ESC on a basic wheel TX.
    • oscarel
      • Dec 2009
      • 2128
      Did you reverse throttle channel? And recalibrate?
      Sent from my SM-S908U using Tapatalk
      • Zondar
        • May 2015
        • 58
        This Radiolink transmitter has way to reverse throttle but didn't work for me.
        I have to keep tension on trigger brake and slowly release for more throttle (backwards).
        Thanks for the quick response,
        I'll keep listing.
        • Zondar
          • May 2015
          • 58
          Castle told me of the pixtix but couldn't tell me where to find part.
          Thanks for your help,
          I'll be listening.
          • oscarel
            • Dec 2009
            • 2128
            There's another way, let me see if I can find the post. Do you have a castlelink to program it via computer?
            • oscarel
              • Dec 2009
              • 2128
              Try this:
              FYI, setting the fail safe resets the endpoints and then the motor runs at neutral when you lose signal (tested by turning off transmitter). To solve I changed the 'Throttle Type' to Fixed-Endpoints and followed the instructions in Castle-Lync. I ended up with 98% on forward and 35% on reverse trims. Fail safe is now safe!
              Fixed-Endpoints
              Fixed-Endpoints will set zero-throttle and full-throttle points to fixed values so that the ESC does not have to learn from your transmitter. If you are using this mode, you will most likely want to change the EPA settings on your transmitter to allow full throttle resolution with the throttle stick. *!**To do this, turn on your TX and set normal mode in the transmitter for a linear throttle curve (0,25,50,75,100). Bring your high side and low side endpoints on your throttle channel down to 25%, plug in the battery pack with the throttle stick at full (it won't start up), then bring your high endpoint back out towards (and sometimes past) 100% until you hear a single tone. Next, bring your throttle stick down to the bottom position and bring the endpoint out from 25% out towards (and possibly past) 100% until you hear the ESC arm. Unplug the battery pack, wait a few seconds, then plug back in and verify that the throttle is working properly.
              • Zondar
                • May 2015
                • 58
                Will give it a try!
                Appreciate ya!
                Always trust a professional!
                Best,
                Z
                • oscarel
                  • Dec 2009
                  • 2128
                  Anytime, hope it works!
