MGM ESC castle 1721 not working electric turbo
  • William boutin
    • Aug 2023
    • 6
    Hey guys, hope you are going great! I have some issues with my set up. My ESC (MGM X2 400) got back from repair and I try my new motor (castle 1721 2400kv) at the same time. I am getting super low input (60A) current and super hight pulse current (450A) and a peak current of 220A I find a thread from 2017 but no real answer.
    Still waiting for a response from mgm
    Now what I did, I currently macking an electric turbo for my car. Long story short, the motor/turbo set-up have been proven to work by a friend on an other forum. But the only difference I have is the ESC and a powerfull battery.
    Last year I had a TP 4070 and I was over volting it and having a crazy 15kw! Great reasult but damaging the ESC
    Now I only get barely 2kw and struggle to not it the cut-off safety. **WITH OR WITHOUT LOAD** by running it in the car or just free spin the impeller without the housing, I get the same results
    My question is, why do I get weird number on my ESC log and why I can?t get it to run properly?
  • DannyB.
    • Feb 2013
    • 10
    Sounds like it loosing commutation..
    What kind of wind is that motor and what kind of timing are you running ?
    • William boutin
      • Aug 2023
      • 6
      My timing is set to 0. I?ve tried to up a little bit the timing at 5 but only that make it worst.
      I talk to Joe from castle creation and he reslly don?t think it?s a motor issue. Y or D winding. I am still waiting for MGM response
      • DannyB.
        • Feb 2013
        • 10
        I'd try auto timing to start with.
        What kind of batteries and what voltage are you running ??
        Is it hitting LVC ?
        Is it getting the right signal ??
        We're going to need more info......
        • William boutin
          • Aug 2023
          • 6
          Why auto timing if I go up in timing thigs just get worst?
          I am running A123 pouch cells 20ah 12s (35.4v in my case) wich the volt drop is about 1.0v. So plenty of power
          For the signals I have no remote, simply a switch direct to the ESC
          • DannyB.
            • Feb 2013
            • 10
            If its a rc esc i cant see that switch working....
            It needs the correct signal to operate properly.
            • William boutin
              • Aug 2023
              • 6
              Switch mounted on a arduino which is plugged direct on to the ESC. Yes it work properly.
              • DannyB.
                • Feb 2013
                • 10
                No it doesnt.... You wouldnt be here if it were....
                Ditch the Arduino and see if it works with a rc controller or servotester.
                I'm willing to bet it's either loosing commutation due to high rpm or the Arduino *!***!***!***!**ing *!***!***!***!** up.
                Using a transmitter or servotester will show which one it is.
                If its commutation it will show up in the upper rpm range , of its the Arduino it just works....
                • William boutin
                  • Aug 2023
                  • 6
                  I am not here for the switch. I did my first bench test witch servotester before the arduino. It did work just fine, my log show a 100% throttle at all the time. Read my post a second time and you will see that I never talk about a throttle problem. The transmitter have no effect on the weird amp that go in vs the peak amp and all of it.
                  • ray schrauwen
                    • 9471
                    The MGM esc might not like the 4 pole high KV motor.
                    Nortavlag Bulc
                    • vvviivvv
                      • May 2009
                      • 1076
                      I really find it surprising the amount of issues people have with MGM's with poor customer service
                      Uk SAW record holder
                      • William boutin
                        • Aug 2023
                        • 6
                        Well, it?s really good when you finally talk with someone
