Need 12 volts to run two water pumps.
  • TRUCKPULL
    • 2975
    I need 12 volts to run two water pumps.( pumps are 400mA @ 12V each)
    The boat is a twin Cat , 8S to each motor.
    I want to wire the output of two of these in series to get 12 Volts.
    What will I also need to do this ( caps, diodes Etc.), and How.
    Larry
  • fweasel
    master of some
    • Jul 2016
    • 4291
    Many ways to skin a cat. I would use a regulator with the voltage you want. This one for example.
    Vac-U-Tug Jr (13mph)
    • TRUCKPULL
      • 2975
      thank you Ryan- that will work.
      Larry
      • RaceMechaniX
        • Sep 2007
        • 2833
        I also run the Pololu regulators to power my pumps. My pumps are very small and barely pull any power so I run them off the receiver power battery. For larger pumps I would run the regulator off the primary lipos.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • TRUCKPULL
          • 2975
          Tyler
          The pumps draw less the 1/2 amp each under load.
          But I still like the idea of a separate regulator for them.
          LJ
