Castle Hydra ????
  • HTVboats
    • Jun 2011
    • 803
    Castle Hydra ????
    A friend sent me this controller to check out and conformal coat (waterproof) When I hooked up Castle link it shows a Hydya and I assume it is a 240 - 2 120's stacked. It doesn't show data logging and seems to be a 4S max controller. Not one I have owned so any info would be appreciaited. I don't want to hook up a battery till I learn a bit more.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
  • properchopper
    rcgoatbuild@snotmail.com
    • 6968
    Mic, the Castle Hydra 240 was a quite popular "go-to" full P controller - go back maybe 10 years or more. I had three in constant rotation with Castle repair (which they were quite liberal in warrantee-ing - if not exactly speedy). I'm still using one (minus the BEC - oops my fault) and it runs my P-Cheetah (TP 4060) very very nicely. You can download the programming stuff and program Timing, LVC, start hard/soft and more.
    • RaceMechaniX
      • Sep 2007
      • 2833
      Mic,
      The hydra's do not have datalogging.
      -Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • HTVboats
        • Jun 2011
        • 803
        Tyler,
        I kind of figured that out when I linked it to the PC. My question is can it run on 6S? Does not have a LVC to match 6 cells.
        Mic
        Mic Halbrehder
        IMPBA 8656
        NAMBA 1414
        • NativePaul
          Greased Weasel
          • 2761
          Assuming that it is a Hydra 240 (and it looks that way to me too) it can run 6s, but it has a linear BEC as opposed to the switching BECs that are almost ubiquitous these days, so you will need an external BEC or battery for 4-6s use.
          From memory you cant set the LVC to 6s, but you can select custom voltage and put 20.4v (or whatever voltage you deem suitable) in there.
          • HTVboats
            • Jun 2011
            • 803
            That helps thanks guys for the info
            Mic
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • Raydee
              • May 2007
              • 1603
              For us the rule on the older Castle ESC's was to run them at least one or two cells less than what they were rated for....so a 6s esc was run on 4s. I ended up going to the newer ice and edge 8s aircraft escs and ran them on 6s with homemade water cooling with great success. I still have one Hydra 240 running in my 4s Whiplash.....its the longest lasting Hydra esc I ever owned.
              Team Liquid Dash
              • RaceMechaniX
                • Sep 2007
                • 2833
                The BEC circuit on Hydra's and even the newer ICE and EDGE controllers is the weak link. We got a lot more life out of the Hydra/ICE/EDGE controllers when we skipped the BEC and used an external receiver pack. Smaller servo's with less torque were generally not problematic, but 200oz and larger servo's strained the circuit. Additionally the higher the input voltage from the batteries, the harder the BEC circuit had to work. i.e. a 2S battery was easy to regulate the BEC voltage, but a 6S battery was a big step down from 22V to 5V.
                Several of us went to the Castle external BEC powered off the main battery to avoid the internal BEC failing.
                Tyler Garrard
