Flier 300amp ESC, Maytech rec'r, UBEC, BLDC config question
  • bigfluffydog
    • Mar 2021
    • 2
    Hello,
    Having trouble getting throttle to work with rest of configuration. Maytech (throttle/receiver manufacturer) said I had to use the BEC (black/green device) in the system.
    New to this and have taken it about as far as I can. Any help would be appeciated. Picture shows unwired components after testing. Not the suggested config.
    Thanks,
    Matt
  • photohoward1
    • 1610
    Why not just use a receiver Battery?
    • Peter A
      • Sep 2012
      • 1486
      The way you have that it will never work!
      The esc needs to plug into channel two.
      Get rid of that horrible looking bec thing.
      Get an rx battery.
      • fweasel
        master of some
        • Jul 2016
        • 4286
        Since you're new to this, let's cover some basics. A receiver needs power, and is usually powered by the ESC when you plug it into the throttle channel on the receiver. This is only the case when the ESC has a BEC circuit built-in. BEC stands for battery eliminator circuit. It uses power from your main battery, regardless of the voltage, to power the receiver with 6V. Your Flier 300A ESC does not have a built-in BEC, which is why you were recommended to run an external BEC. As several other members in this thread have mentioned, the preferred method with the higher amp ESC's is to not use an external BEC in favor of using small LiFe receiver battery that plugs directly into the receiver on any open plug. I like to use the 900mAh Spektrum battery available at OSE.
        Vac-U-Tug Jr (13mph)
        • bigfluffydog
          • Mar 2021
          • 2
          thanks to those that responded. I have extra batteries, I'll wire one of those up to the rx. Then I'll change the rx to channel 2 and see how that works. I thought you just plugged it into PWM pin. that could explain why it won't sync to tx. Like I said, new to this. I'll update when I'm able to work on it again (3 days
          • Old School
            • Aug 2017
            • 686
            Matt,
            something to consider about battery type. Many use a 2s LiFe battery because it is 6.6 volt (3.3 volt per cell). This is for a typical receiver voltage between 4.8 and 6.6 volts. If you use a 2s Lipo battery then the minimum voltage seen will be 7.4 volts (3.7 volts per cell). High voltage receivers (7.4 volts) are used when the servo requires a minimum 7.4 volts. Many report no issue using a higher voltage 2s Lipo on a basic receiver, but really a LiFe should be used.
