MGM esc programming problem
This is a sticky topic.
  • RaceMechaniX
    • Sep 2007
    • 2833
    #91
    They are provided for Anti-spark. The 22 Ohm is for 0-15V, the 47 Ohm is for 15-63V and the 100 Ohm is for 15-120V.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • triton
      • Jun 2015
      • 48
      #92
      Some new info about MGM-TP pair.
      I was on the lake two days for testing. That was very cold but must to run:)
      So the end of the 2nd. day the setup was stable. The program I think a bit extreme because must to use very high timing 28 degree for the D wind motor!!!!
      The max esc temp 34 celsius.
      The motor temp was 20.8 celsius.
      The p16 acceleration parameter 4s.
      The max speed 126km/h what very low....(10S)
      I have better experience with same setup with a little lehner 2250/10.
      My experience the MGM-Lehner works much better then the MGM-TP or MGM-Serious combo.
      • RaceMechaniX
        • Sep 2007
        • 2833
        #93
        Have you tried timing below 10Deg?
        Tyler Garrard
        • photohoward1
          • 1611
          #94
          What does everybody or anybody think of auto timing?
          • triton
            • Jun 2015
            • 48
            #95
            Yes
            Tried with 0-3-6-7-8. Always was motor blocking.
            • triton
              • Jun 2015
              • 48
              #96
              Some logs
              Input / peak current and input voltage.
              When I tried with lower timing the input current was much higher like now.
              But I think somethings wrong with the batteries but all new turnigy heavy duty 60C.20171219_205921.jpg
              • triton
                • Jun 2015
                • 48
                #97
                • RaceMechaniX
                  • Sep 2007
                  • 2833
                  #98
                  Howard, I would only try auto timing with the LMT's.
                  Triton, I would be careful with the high timing. I am surprised it works, but data does not lie.
                  Have you tried using low timing and increasing the switching frequency?
                  -Tyler
                  Tyler Garrard
                  • triton
                    • Jun 2015
                    • 48
                    #99
                    -Tyler
                    No.
                    Tomorrow will try it.
                    What you think about the battery voltage?
                    • RaceMechaniX
                      • Sep 2007
                      • 2833
                      #100
                      The battery voltage is not great, but I assume the batteries were not warm at the beginning of the run.
                      Towards the end of the run they were improving. It also looks like you were not starting with fully charged cells. 40V instead of 42V for a 10S pack.
                      Also notice that the current increases towards the end of the run.
                      The Turnigy HD cells are pretty decent cells by the way.
                      -Tyler
                      Tyler Garrard
                      • dmitry100
                        • Mar 2015
                        • 1264
                        #101
                        Tyler, I've been thinking of making a similar type of Dyno setup to test ESC's before putting them on the water - know of any cheaper EDF fans that can handle high RPM's and amps that don't cost like $800 ? :)
                        • RuntheraceAMC
                          • Sep 2016
                          • 222
                          #102
                          Triton,
                          What TP are you running?
                            #103
                            ?..What TP are you running?
                            See post #5.
                            • RaceMechaniX
                              • Sep 2007
                              • 2833
                              #104
                              Not any I would trust spinning over 40kRPM.
                              Tyler Garrard
                              • Meniscus
                                Refuse the box exists!
                                • Jul 2008
                                • 3225
                                #105
                                I'm not interested in re-hashing this subject, but I wanted to provide a little perspective and results from the low voltage side of things.
                                I've probably put in over 300 runs on one of my MGM 280A controllers and over 200 runs on my backup. For a number of years, I have used 6-pole motors (not TP) on 2s setups. Consistently, I run 160A on a D-wind motor up to around 200A, making as many as 6 SAW passes at a time. Running lower timing and a higher switching rate, I haven't run into any issues or current limiting. I have also turned some very large props without issues.
                                In my case, I am limited by the current limits for the motor, regardless of whether it is an off-the-shelf motor or one that I have hand-wound. Typically, on 2s, my motors have a limit of 2200 watts continuous which puts me pretty close to the 280A limit. However, I hardly ever get to that limit with my setups. To do 280A or so on a 6-pole motor, I would have to turn a 50mm prop which is completely crazy in a 2s setup, in my humble opinion.
                                I have similar experiences with 6-pole motors running on 4s.
                                Regarding Tyler's comment about wonder who has really fried MGM controllers, I have cooked only one 280A MGM. The SAW setup was using a LMT motor, but it appears that a couple of the aftermarket caps failed and with the longer wires (4" as I recall) I needed to position the cells in a small 2s sport hydro. I would consider this situation to be operator failure and not an issue of the MGM controller.
                                With proven reliability, I would say that with proper motor, model and prop matching for the load and RPM, the 280A MGM does very well on lower voltage, even with higher pole inrunner motors. It is clear that all ESCs suffer from time to time with different motors and setups, but it is likely that we are asking more of the motor than what it is able to deliver.
