Please can someone let me know i have just bought a swordfish pro plus 2 hv esc and its says it comes with no bec, Do i need to put a ubec to my set up, ?? My set up is twin sss 1650kv and twin esc, OR what is best please and thank you....
ubec
Yes you will need a external bec if your esc did not come with one or a separate battery pack. These are good:
https://www.offshoreelectrics.com/pr...as-010-0004-00
https://www.offshoreelectrics.com/pr...as-010-0153-00
Here's how to wire it:
https://www.offshoreelectrics.com/wiring.phpComment
Thankyou again for your last advise, but can i ask , Do i still have to remove red wire from both speed controllers after hooking up my bec, ??? Or do i not need to,?? do i need to use two becs one for each esc or just the one, Sorry for such basic questions but i am new and still learning, Thankyou,,Last edited by frankie; 10-19-2017, 09:47 AM.Comment
You connect the two esc's with a Y harness to the throttle channel on the receiver and wire a single Ubec in to power the receiver. You should not need to remove any wires unless the esc has an internal bec in which case you remove the wire from one esc so only the other is supplying power to the receiver. See below for OPTO with external bec, although for aircraft the diagram my help. What boat?
How-to-wire-up-a-twin-Brushless-aircraft-rev2.pdfComment
Or depending on which way you want to go. You can run a batt pack and eliminate the bec wiring and dedicate your main batteries to propel the boat. https://www.amazon.com/gp/aw/d/B00JN...y6L&ref=plSrch I’ve yet to have any problems with this brand or chemistry. Charge it as 123 chemistry.Comment
Thankyou, What do you think is a better way?? A (life) battery pack like you said or do think bec is better, Me i will run with the experience that you recommend until my knowledge gets better buy learning, but in mind I'm thinking bec to keep weight down and room in the boat, or is there a advantage on battery pack??Comment
