The new Swordfish'
  • Erroneous
    • Apr 2016
    • 451
    8s in the new trim. The 300s weigh in at 490g
    • CraigP
      • May 2017
      • 1464
      Yeah, switching amps ain't easy!
      • Dragon-Fly
        • Jan 2014
        • 7
        The weight is about 370g which I have measured!
          300 or 220? The 300 is listed at 490 lol
          • MadProps
            • Mar 2017
            • 236
            I ordered a 220 from OSE a couple days ago....I just blew a seaking and was in need but the integrated data logger is what caught my attention
            • photohoward1
              • 1610
              Originally posted by CraigP
              Photo, isn't it really expensive? I agree an electric boat will always out accelerate a gas boat. I'm making my statements not to the die hard racer, but the guy that just wants a fast sport boat. If your racing, then all bets are off on safety tolerances. I'm trying to help the guy that doesn't want to break a bunch of parts. Racers don't need my help, at all! But that doesn't mean that sport boaters don't count.
              I agree. A flier at 200-300 is considered cheap for 10-12s. A 240 swordfish would work too. No problem sporting at 50+ on those and a nice 40+" hull
              • CraigP
                • May 2017
                • 1464
                Raise that batt voltage and prop down, watch those amps drop. I'm recommending higher voltage setups to folks because running lower amps is the sure ticket to really slow up breaking expensive parts. But you have to be disciplined and use data logging to set your power draw. You can make a very reliable boat if you follow thru with that game plan. The racers are in a tough position. Class rules restrict your batt voltage, which drives your current up and puts ESC's, motors and batteries at greater risk. If you have a boat, using 250amps at 4s, then you can run 8s and halve your current! But you have to change the motor and prop to yield a speed result similar to the original setup. But anyway you slice it, the 125a is much safer than 250...
                • Dragon-Fly
                  • Jan 2014
                  • 7
                  #23
                  It is the X plus 300, measured again = exactly 395g!
                  I will try it at the Munich SAW (September 21-24) in my Vector 45 with a TP5840s/4Y at 6s and 8s . I burnt 3 other escapes this year and I hope this one keeps alive.
                    Got my 220 in yesterday. Built much better than the older one. The circuit boards look different too so it seems to be a fresh design. The whole case is aluminum. The circuit boards are epoxy coated. So far I'm liking what I'm seeing.
                      • 7673
                      #25
                      Sounds good Trav, hopefully a solid unit
                      • Bp9145
                        • Jan 2016
                        • 1466
                        #26
                        That's good to hear. I just hope it's as good as it looks. As you know, looks can be deceiving. Maybe if a lot of us write to them if we ship back our older failed SF escs, they can give us credit towards purchasing the new versions. . .wouldn't that be nice. . .
                          Well unfortunately I haven't run it yet. Oddly it won't fit in my Rivercat but will fit in a mini Rivercat lol. The reason is the depth of the hatch rail is much deeper on the 32". I ended up putting a raider 150 esc in the Rivercat for now. I'll put the sf220 in my mini, it may not get built for a few weeks as I have other stuff on the work bench needing finishing first.
                          • jim82
                            • Jan 2013
                            • 1358
                            #28
                            How well are these working out?
                              • 7673
                              #29
                              I am curios too. I haven’t even got to run my old SW 300’s.
                                I put it in my mini but the weather hasn’t allowed me to run it yet. I probably could have gone to the small end of the lake and tested it but I’ve just been to busy. I have three boats awaiting maiden and testing voyages.
