Donhuff when I read that your two ESCs failed with the same motor (a used one to boot) I remembered ESC failures I have had. About twelve years ago I overheated a Hacker XL motor (over 190* on the can) but put it in the motor box and thought little of it. A year later I put it in an oval cat and after three laps the ESC (a Hacker) burst into flames. It was a well-used ex-SAW ESC so I thought little of it. A few months later the same boat/motor combo blew a proven Castle Barracuda. This was all with round cells. It finally dawned on me that the motor was the only thing common to both failures and was likely the cause of the ESC failures.
More recently I was setting up a SAW hydro in a new hull and just wanted a moderate setup to start to trim the hull. A brand new Castle ICE, a brand new Neu 1527, brand new packs. Less than twenty seconds after leaving the beach (no WOT) the ESC blew. Darn, I thought the setup was moderate. Cleaned up the boat and used a different motor to set some records. A year later, same thing with that new 1527 - 20 seconds and another roasted ESC. Yep, bad motor.
Moral to the story, the ESCs may have been taken out by the motor. Bad magnets will raise the effective Kv and reduce efficiency substantially, with the expected result. A shorted wind can do the same. Or, the ESCs could have been bad. Food for thought.
