swordfish 300amp pro + vs seaking 180amp esc
  • twonb1
    • Jun 2015
    • 54
    So I recently changed to a swordfish 300a pro + from a hobbyking 180a. After I gps'ed the boat today, Its seems I have lost about 5mph just from switching escs. I did not make any changes to the boat at all. Same batteries. same props and the same water conditions. Any thought?
  • dmitry100
    • Mar 2015
    • 1264
    If anything the SF300 will give you more power.
    Unless SF300 ESC firmware settings are different and set to give you less power (set Motor Timing to Auto), etc.
    • twonb1
      • Jun 2015
      • 54
      That's the wierd part. I adjusted the swordfish setting as close as i could to the settings of the Hobbyking 180a with no luck
      • fweasel
        master of some
        • Jul 2016
        • 4282
        Throttle calibration?
        Vac-U-Tug Jr (13mph)
        • oscarel
          • Dec 2009
          • 2128
          Can you explain how it would give more power??
          Sent from my SM-G930T using Tapatalk
          • twonb1
            • Jun 2015
            • 54
            Throttle calibration was done correctly per instructions.
            • rayzerdesigns
              • Dec 2013
              • 1228
              After u calibrate speed control go back in to ur radio and turn throttle end point up to 125%
              • photohoward1
                • 1610
                Calibrate at 100% and then up it to as high as it will go. This will solve the problem.
                • twonb1
                  • Jun 2015
                  • 54
                  any other answers
                  • T.S.Davis
                    • 6221
                    I've about thrown in the towel on the 300. I have two. One does exactly as you discribed. The other doesn't fire at all. Frustrating.
                    Noisy person
                    • 427srule
                      Racer
                      • Nov 2008
                      • 164
                      You mention you have a Pro + which includes data logging
                      A few years ago my CC LV240 exploded and I switched to a SF 240 with the data logger. I lost 4 mph and was never able to get it back.
                      Keith Bradley notes on his site that the Data Logger does have an undesirable effect on performance. http://keithbradleyboats.com/product...swordfish-300/
                      Thank you,
                      Michael
                      • twonb1
                        • Jun 2015
                        • 54
                        ok thanks I will be looking into this link you provided as soon as I break free from work
                        • dmitry100
                          • Mar 2015
                          • 1264
                          427srule, if you think datalogging is the issue you can try lowering the data logging refresh interval setting in the SF firmware software change the default to log once every 5+ seconds and see if that makes any performance improvements for you.
                          But either way, it might have something to do with the efficient design of the controller.
                          • oscarel
                            • Dec 2009
                            • 2128
                            What do you have the timing set to? Did you see this thread? http://forums.offshoreelectrics.com/...fyi&highlight=
                            • 427srule
                              Racer
                              • Nov 2008
                              • 164
                              [QUOTE=dmitry100;676232]427srule, if you think datalogging is the issue you can try lowering the data logging refresh interval setting in the SF firmware software change the default to log once every 5+ seconds and see if that makes any performance improvements for you.
                              But either way, it might have something to do with the efficient design of the controller.[/QUOTE
                              Dmitry - Thanks for the tip
                              I will have to give it a try
