Esc for 1527 1.5D
  • StevenBryant
    • Nov 2012
    • 359
    Esc for 1527 1.5D
    Hey guys which is the best esc to use with the 1527 1.5D motor?
    I run the MGM esc on most of my boats however I remember reading on here that people where having problems using the MGM esc with the NEU motor.
    Cheers
    Steve
    That depends a lot on what your amp load will be. A seaking 180 will run it but depends on the load placed on it. If the parameters are set correctly the mgm should play nice with that motor. I have a 25035 x2 in a mono that has a 6pole dynamite motor in it and it plays nice. I did take the motor apart and it looks identical in construction to a castle motor or older neu motor except six poles. Iirc the default on mgm is two poles so you need to change that.
    • StevenBryant
      • Nov 2012
      • 359
      Thanks Kfxguy
      I will be running it in a hydro so the current draw will be quite high so I really want to be sticking with high end esc's, MGM if possible.
      Are the xl2 esc any good when converted to marine?
        Originally posted by StevenBryant
        Thanks Kfxguy
        Yes I like them. Seem to be tough as long as you don't get wet. I epoxy coat the board on mine.
        • StevenBryant
          • Nov 2012
          • 359
          How easy was it to remove the heatsinks off the field esc?
            Unscrew plastic halves. Pull apart and slide wires through holes. Then very lightly pry them apart. I did two of them with no issues.
            • StevenBryant
              • Nov 2012
              • 359
              Thanks, I'll give it a go with my spare TMM28026-2 first and see what happens.
