Is auto ESC timing proper for delta wind motor?
  • zooma
    Local club FE racer
    • May 2014
    • 652
    I am setting up a Q mono with a Leopard 4092 1480kv 3.5D wind motor, and Swordfish 220 Pro+ ESC on 6 cells. This is my first delta wind motor. My research here and elsewhere shows that delta wind motors like low timing as compared to wye wind. On my wye winds, I use auto timing if the ESC has that setting, and 5-10 deg if fixed only. I expect to use auto timing on the delta wind motor, unless advised not to. I am looking for practical experience from forum members. Thanks.
    Ron - The Villages, FL
  • Jamey
    • Apr 2015
    • 199
    Zooma, FWIW I run 3.75 degrees in my Seaking with that motor. Runs well but I need to do further testing at other settings to know anymore.
    • RaceMechaniX
      • Sep 2007
      • 2821
      If you have fixed timing try 5 Deg or less first. Make a short run and check temps. You can try upping the timing, but you will likely only get more heat and no more performance.
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • 785boats
        Wet Track Racing
        • Nov 2008
        • 3169
        I always use the Auto setting on the Swordfish ESCs for both Star or Delta motors.They always seem to run cooler than when you try to select a setting.
        • zooma
          Local club FE racer
          • May 2014
          • 652
          ok, still planning to use auto
            Auto works the best for me with sf escs. No matter if they are delta or wye.
            • ray schrauwen
              • 9471
              I'm going to try this in one boat since any specific timing settings will not let me get 6+ laps out of it. If that doesn't work, the motor may be on the way out.
              Nortavlag Bulc
              • zooma
                Local club FE racer
                • May 2014
                • 652
                Thanks. I was hoping to here that.
