Hi all running a UL-1 2030 kv 6 pole with ETTI 150 amp esc in my outrigger last summer just checked the timing on esc and found it set at 2 degree advance which is for 2-4 pole motors .Would running a 6 pole motor in a 2 pole setting cause damage to motor or esc? Regards Andris Golts.
ESC timing ?
Tags: None
I run timing at around 10 degrees some go up to 15. Low timing on these motors may not be the best or most efficient.Nortavlag Bulc
The stock esc that came with the UL1 was set at 12 Degrees also.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & WetComment
