1 ESC 2 Motors
  • flraptor07
    • Aug 2013
    • 2451
    1 ESC 2 Motors
    Is there any reason you can't run two motors off one ESC, for instance a 240amp Swordfish pro plus with two 4060 tp 1860kv on 8s this combo will be in a Drag boat. So no long runs just short bursts.
  • egneg
    • 4670
    I did it a long time ago with brushed motors ... not sure how it would work on a brushless setup.
    IMPBA 20481S D-12
    • flraptor07
      • Aug 2013
      • 2451
      I think I'm gonna hook it up on the bench and see how it works, as long as both motors react the same it should work.
        if not its going to be an expensive lesson.....lol
        • flraptor07
          • Aug 2013
          • 2451
          Aw hell, what's the worst that could happen
          • ray schrauwen
            • 9471
            I've seen it done on on Youtube with a T180 and a pair of T600 motors if I'm not mistaken. Does work to a degree but, one motor may start before the other and one might turn the opposite way on occasion too.
            • RayR
              @SiestaKey.calm
              • Jun 2007
              • 1518
              The esc will get confused with conflicting rotor position reports from two sources.
              • flraptor07
                • Aug 2013
                • 2451
                Wouldn't that be on sensored motors?
                • RayR
                  @SiestaKey.calm
                  • Jun 2007
                  • 1518
                  You are correct, sorry.
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    It works, a member here tested with up to 4 motors several years back and posted it, vids are on youtube. Amp draw will be your main concern
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      Here's one of his vids:
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        Here's one of his that is more technical, hooked up to a computer and has the motors under load he tests thrust etc.......
                        • ReddyWatts
                          • 1711
                          http://forums.offshoreelectrics.com/...t=no+load+amps
                          ReddyWatts fleet photo
