Using a Castle ICE Aircraft Controller in FE boats
Would a stick transmitter work better with the castle esc's or would a pistol transmitter like a spektrum dx5r work just as good?
Can't seem to get the Fixed Endpoints throttle type to calibrate on my 2 castle edge 200's with my futaba 4pls.
1 controller consistently pulls 5-10k RPM higher than the other while the other motor is at standstill
Sent from my SM-N950U using TapatalkTeam Liquid DashComment
Dmitry
I though this problem got solved for you in the other thread by Tyler Garrard???
https://forums.offshoreelectrics.com...-Lehner-motors
Starting at post #97
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & WetComment
It was solved, I'm still trying to set the correct trims to acheive full rpm at full throttle by matching the data logging
Even though its solved for the most part and finally calibrated -- I still notice that each ESC seems to take turns spinning at 10% - 15% throttle blips... It's not a big deal. It's just strange. I assume this is the "castle issue" Tyler mentioned where each castle ESC seem to vary when used for twins.
It's as if throttle signal slightly varies for both ESC's even tho its connected to the same Y cable.
I'm sure it'll run fine now on the water once it gets going and won't cause the torque roll flips I experienced when previously.Comment
Torque Roll with a twin when turning at speed.
If you have your props turning inbound, you will have problems turning at speed.
When you turn the outside motor loads up in a turn, and the torque of that motor is now trying to rotate the boat even more to the outside, causing a flip.
This is why I run my props outbound on my twin race Cat, when the outside motor loads up in a turn, the torque of that motor is now trying to hold the boat flat on the water.
I have found that I can now turn at almost full speed. My "Q" Cat runs at a full speed of 70MPH.
The top speed of the boat would be a bit faster with inbound props in a straight line, but cannot turn without slowing down (FLIP)
I do not know if this will work,
Above is a old video of my cat , when I was still setting it up.
LarryLast edited by TRUCKPULL; 04-30-2018, 02:29 PM.Past NAMBA- P Mono -1 Mile Race Record holder
It was a pretty slow SAW pass
and I do understand what you're saying but this was not the case
Just trying to get the TX to get to full throttle -- the maximum "Throttle In" I'm getting from data logs is 1.965 ms -- One of my other data logs showed Throttle In of over 2.1ms
What is the max value I should be shooting for?Comment
Any of you guys have any idea of just how accurate the Castle data logging is supposed to be?
I had a separate external data logger hooked up to it complete with current and rpm sensors and all of the data in comparison compared to castle’s was about 2x higher. My data showed max of 40k rpm and 250 amps... castle showed max of 25k rpm, 40% Power Out, and 100 amps. Castle data logging was even set to record at 5x per second.
Kind of weird. Seems like some pretty useless data...Comment
If the pole count is not correct for the motor, the rpm will be incorrect. By entering the correct pole count, the rpm shown in my Castle logs matches well with the speeds the boat is running.
I've checked before and the pole count was set correctly to 2 pole. But I'll make sure
Either way, the amps sound a little off -- is it calculated different than what a current sensor between ESC and battery would come up with?
Even the watts were at 1,400 on castle but 3,300 for my logger.Comment
Have you checked the actual amp hour usage? Time a run and see how much you put back into the packs. Compare that to what the loggers show you used. Then you’ll know.
My Castles all show virtually identical amps to what I actually used. This also means that watts are correct.
What is your exact setup?
Has anyone found a good place to buy the 1/8" aluminum extrusion from besides the one that Brian posted? They want $35 to ship a 4' piece...kinda pricey. I have an Edge 200 lite and would like to water cool it asap.Team Liquid DashComment
ShawnComment
You don’t necessarily need those particular extrusions. You can make (bend) some L shapes with thin copper or aluminum and use Arctic Silver epoxy (amazon) to glue 1-2 tubes on each side. If you have the original aluminum heat sinks that came with the Phoenix edge 200 — you can simply glue tubes direct on it.Comment
