Don't be surprised if it's the 75mhz radio giving you fits.
most Reliable ESC
I know you guys are just ribbing each other. Personally I think it's funny. But some might not think so. Can you please put some indication that you are joking so
others won't think this is a hostile forum? Thanks...Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
I have given up on the old radios I have a new Futaba 4PL-S and love it. you are right TerryComment
Grown men playing with toy boats fellas.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
Chris the prop really depends on the motor and kv. You will have to have an amp meter and test with different props. My motor was a Hacker outrunner that could swing a 12" prop at 10s and a 16" prop on 6s. It all depends on your setup. These small boat motors I would start with a 4.7x 4.7 prop and see what you get. They make prop adapters for 5mm shaft so it's easy to mount an airplane prop on the motor. You might have to get an airplane motor mount or you could make your own out of aluminum.
MarkComment
Chris, Ive done prototype RC plane design stuff for years...loads of testing..gas to electric, prop to ducted fan....no need for the strut and flexshat, unless your wanting to test those too...which would be a really nice feature to have, specially for us "SAW" guys..comparing load/drag between different struts,shafts, couplers etc ... you need an adapter to fit the prop shaft, alot of airplane props come with different sized hole inserts to fit multiple shafts...as Mark stated a 4.7 x 4.7 would be a really good starting point....a inline voltmeter thats been shunted to do up too 300amps and you got the ultimate test stand.... DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
Chris.
Here's my old set up for testing motors, batteries, ESC's etc. A bit industrial perhaps, but with the watt meter logging all the Volts, Amps, Mah used, watts, peak power etc, its very useful. Plus you can watch the numbers change in real time while you are testing. Great for discharging packs too.
Like DJ said, all you need is the airplane prop adaptor on the motor.Attached FilesSee the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Mark
Chris, Ive done prototype RC plane design stuff for years...loads of testing..gas to electric, prop to ducted fan....no need for the strut and flexshat, unless your wanting to test those too...which would be a really nice feature to have, specially for us "SAW" guys..comparing load/drag between different struts,shafts, couplers etc ... you need an adapter to fit the prop shaft, alot of airplane props come with different sized hole inserts to fit multiple shafts...as Mark stated a 4.7 x 4.7 would be a really good starting point....a inline voltmeter thats been shunted to do up too 300amps and you got the ultimate test stand.... DJComment
Chris.
Like DJ said, all you need is the airplane prop adaptor on the motor.Comment
