Need help adding capacitors to ESC
  • Kaotic
    • Jul 2014
    • 447
    I'm thinking about soldering on 2 more capacitors to the small cap bank that came with my seaking 180 ESC. I cut the shrink wrap off to find the two - 35v 390uf caps, but there is a small little black box thing in between the 2 caps. My plan is to solder on 2 more caps to the under side on them, but what is that black box??? If I solder them on is it going to screw something up?
    Michigan Fast Electric SAW Club
    Revolt - 76.9mph...Building a DF35- Project Mono
  • bayareaheli
    • Jul 2014
    • 144
    Double post
    • bayareaheli
      • Jul 2014
      • 144
      Looks like a mosfet, might be easier just to add a complete seperate cap bank like an ETTI one.
      Im not sure why they are using a fet there but you could also stack another fet on top and 2 more caps
      • Rumdog
        • 6453
        Better off just removing them and adding two bigger, better caps.
        • Kaotic
          • Jul 2014
          • 447
          I'm still learning about capacitors, what does an FET do?
          Also which caps would you recommend I buy?
          Thanks
          • ray schrauwen
            • 9472
            Why do you say it is a FET ??
            Most likely a resistor.
            Nortavlag Bulc
            • Kaotic
              • Jul 2014
              • 447
              image.jpg Here is a closer look at it.
              • Luck as a Constant
                Make Total Destroy
                • Mar 2014
                • 1952
                Let me ask this.... Does the esc need more caps for some reason?
                • Kaotic
                  • Jul 2014
                  • 447
                  Well the caps I have now get to close to 160 degrees after about a 3.5 minute run, so I figured I'd add a few more.
                  • bayareaheli
                    • Jul 2014
                    • 144
                    because i looked up the part number, so im guesing it is there for switching back in forth between caps.
                    • bayareaheli
                      • Jul 2014
                      • 144
                      Thanks
                      you can find all the parts you need right here
                      http://www.offshoreelectrics.com/pro...ories+%26+More
                      • tlandauer
                        • 5666
                        That is quite hot, but no where near the threshold, but I agree with you that lower is far better.
                        Which version is the ESC? I dread the day I have to use the current version3!
                        • Kaotic
                          • Jul 2014
                          • 447
                          It's the 180a V3. Running on 4s 65c to a 3674, revolt. runs great I'm just worried about temps.
                            Add a castle cap bank to it.
                            • tlandauer
                              • 5666
                              I don't mean to bash the new version, it's just that the way they did the caps which prevents a clean installation of a cap bank, I have many V2 of this ESC with a cap bank added. Also the Capacitance on the older one is higher, may be it is not needed with the newer ones? I have no idea.
                              Going back to your original question, the box looks to me like a SURFACE MOUNTED CAPACITOR? That was there between the caps on the older version as well. If i were you I will add a cap bank that somehow " splices" into the main power lines, so there is no unnecessary soldering or de-soldering on that tiny plate.
                              Just my $.02
