Castle esc discontinued
  • Doby
    KANADA RULES!
    • 7280
    #76
    Originally posted by PatrickM
    Can't speak for others, but I started using the aircraft ESC's when CC dropped all marine products except for the Hydra Ice 240 and the Hydra Ice 200 HV. Couldn't justify using a massive $400 controller for spec racing........
    Who the heck needs a 200/240 amp controller for spec racing (assuming P-Spec)
    Grand River Marine Modellers
    • ray schrauwen
      • 9471
      #77
      You missed Post#71....
      Nortavlag Bulc
      • olwarbirds
        Magic Smoke Wizard
        • Oct 2012
        • 1136
        #78
        Howard: You are right, I really like the newer version of SF240 I have in my 40" mono, runs great and cool.
        Pat: Understandable. Jay Turner gave me some good info too, thank you.
        Ray, when you refer to "newer version" are you using the Pro or Pro+ ....Im going to need something that works well with a Neu 1527 in a 6S setup...tks...DJ
        • ray schrauwen
          • 9471
          #79
          Well it's between the first version and the Pro I think, I'd have to try and pull the big mono down to see. I bought it in the swap shop in the early fall. It has rubber encasement. I'm running it with a 1200KV SSS HOR 5684 motor, 6s2p 10kMah.
          Nortavlag Bulc
            • 8012
            #80
            No one. Castle stopped offering a low amp marine controller, so Pat modified an ICE100.
            • tlandauer
              • 5666
              #81
              I am intrigued with the idea of using their 1/5 ESC, but they don't say how many amps it is rated at? http://castlecreations.com/products/mamba_xl2.html
              I know Darin suggested the 1/8 scale ( they call it water proof) ESC, but the continous amp rating is not that high. (120A)
              What are the thoughts?
              Thanks
              • cybercrxt
                • 2909
                #82
                Just added a bunch of converted to water cooling ICE esc's in the for sale section. Mike
                • T.S.Davis
                  • 6221
                  #83
                  I'm going to try some Alien ESC. There have been changes to them since Fightercat was selling them. Hopefully the kinks are worked out. Tom and I ordered a half dozen to violate when the water thaws. I'll let you guys know how it goes. If we can't bake them they might be okay.
                  Noisy person
                    • 8012
                    #84
                    Since it is designed to go with the 2028 motor it has to be over 100 amps; they say it can "pump out" 10 horsepower, which on 8S is over 200 amps. Actually in size, weight and appearance it looks a lot like the EDGE 200 controller with a fan attached - but it is significantly less expensive. For what it's worth Kershaw Designs lists it at 160 amps continuous.
                    My guess is that it is a ~150 amp controller.
                    • tlandauer
                      • 5666
                      #85
                      Thank you very much, I could not calculate that "10hp" into amps!
                      • fas
                        There just toy boats
                        • Jan 2008
                        • 446
                        #86
                        OK so I just got 2 of the ice lite 200 I have read on how to water cool them does anybody have a pictures of what it looks like after your done just want to make sure I am doing it right and not going to let the smoke out
                        Fred
                        Once you strip all the aluminum heat sink junk off the ICE240 there isn't much left. Just a single board with metal bars along the edges and surface-mounted FETs. A real easy method which works okay is to glue aluminum plates on the top and bottom of each side of the board - the plates must touch the FETs and the bars along the sides. Then glue an aluminum tube to each plate. You have to use a thermal-transmitting glue like Loctite 384 adhesive and 7387 activator for the plates. I prefer a high-silver epoxy for the tubes. Then heat shrink the whole thing, the whole controller ends up being much smaller. A machined extrusion works a bit better if you can find one. Just make sure that the left and right sides have NO electrical connection or they will let out the smoke...
                        Here is a photo of a Castle ICE 200 Lite, which looks identical to the HydraIce without the heat sink junk, and a smaller one opened up to show what I am talking about. The latter would need the gummy stuff removed before attaching cooling plates.
                        [ATTACH=CONFIG]111025[/ATTACH][ATTACH=CONFIG]111026[/ATTACH] .
                        When all else fails floor it
                        • HTVboats
                          • Jun 2011
                          • 803
                          #87
                          That Castle Mamba XL looks like you could exchange the fan for water cooling tubes fairly easily. Anyone converted one?
                          Mic Halbrehder
                          IMPBA 8656
                          NAMBA 1414
                          • flraptor07
                            • Aug 2013
                            • 2451
                            #88
                            I'm using SF 220 Pro+s on both my Q setups Mono and Hydro, Neu 1527 1250kv on the Mono and Neu 1527 1500kv on the Hydro. So far both have been flawless, and the Data logging feature is nice to have.
                            • ray schrauwen
                              • 9471
                              #89
                              Thanks for the input flraptor07. I have not been able to test mine since everything is frozen here until end of March.
                              Very cool!
                              Nortavlag Bulc
                              • ray schrauwen
                                • 9471
                                #90
                                It's a Pro, no data logging.
                                Nortavlag Bulc
