Castle Hydra Firmware
  • properchopper
    • 6968
    #136
    [QUOTE=D. Newland;72320] But, if you go to a D motor or some other setup that requires less timing, you'll need 1.04. /QUOTE]
    That may why , when I installed a 1521 1.5D, it was a slug with high battery temps. Ouch.
    • TRUCKPULL
      • 2969
      #137
      Joe
      The only problem that I ran into was:
      I changed one of my CC125’s over to V-4
      I could not get it to recalibrate to the radio.(would not recognize full brake)
      Changed it back to V-3 and recalibrated it to the radio on the first try.
      Changed it back to V-4 again, then checked all radio settings, I found that I had the brake set to 50%. Reset the brake to 100% and tried the recalibration. It worked on the first try.
      Why would the radio calibrate with the brake set at 50% with V-3, and not V-4???
      Larry
      • Flying Scotsman
        Fast Electric Adict!
        • Jun 2007
        • 5190
        #138
        Tony, 1.04 is great as long as you recalibrate. If the ESC green light is blinking on full throttle...it should be steady...recalibrate as Joe has described.
        Douggie
        • Ub Hauled
          • Aug 2007
          • 3031
          #139
          [QUOTE=properchopper;72325]
          Do it, Do it, Do it, Do it, Do it, Do it, Do it, Do it,
          no pressure...
