Turnigy programming card ?
  • G-UNIT
    • 949
    Just got a programming card for t-120 and t-180 esc and can't seem to get past the basic settings.
    the display only goes to item 4 and will not continue to the advanced settings to set timing, lipo cells ect, what am I missing?
    I can program with the tx no problem but not getting to far with the card, any help here would be great. thanks.
  • G-UNIT
    • 949
    Any one?
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      There are only 4 items to change. I don't understand the problem
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        You use item key to switch thru items you want to modify, and value key to set the desired setting for the item, then hold ok button till it blinks after setting each item
        • G-UNIT
          • 949
          Found some thing in my search, the card hk sent me has the car face plate on it and not the boat face plate which only has 4 settings,
          so I printed the boat face plate and will go with those settings.
          I read that the cards are the same.
          When I ordered my new esc this was an add on sale, so they say.
          at only 5 bucks I'm not to upset if it does'ent work.
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            Oh, well good luck man
            • BlackSnakeRacing
              • Sep 2012
              • 59
              it'll work, you just need the boat face plate. i have one that i have been using for a long time, it still has the car face plate on it, i have just cut the settings list from the manual sheet that comes with the esc and stuck it on the lid of my battery box. The reason for this is that i use it for cars and boats, and there are less settings for the boat esc's so it was a smaller piece of paper i needed to keep safe.
              Cars and planes are for fun... Boats are for serious racing Bust Out Another Thousand
              • G-UNIT
                • 949
                Yes I got it, I found an old post which showed both face plates so I printed the boat face plate and reduced it to fit the card and it should work fine.
                it was just weired that there 12 items and the card only went up to 4, I guess it has to do with the esc, boat vs car or plane, but thank you for your responce.
