Castle Esc problem... I think? Help anyone?
  • Skullcracken
    • May 2010
    • 617
    I have a 45" MHZ Mystic with two hydra 240's and leopard 4082 2200kv motors with 5s to each. Running on X447 props. When I full throttle it, it runs fine but slow, maybe high 40's. Then about 60 feet cuts off, and withing 1-2 seconds will go again. After I run it full throttle briefly, when I try to slowly bring it in, it zig-zags as if the esc's are programmed at different timings and one throttles heavier than the other. Totally confused. i don't know if I have bad esc's or bad motors.
  • oscarel
    • Dec 2009
    • 2127
    A little more detail on how you have the esc's hooked up will help. Picture too if you have it. Are you using external bec's?
    • RaceMechaniX
      • Sep 2007
      • 2821
      Several questions:
      Are both running the exact same settings?
      Do they both have the same software cal?
      Timing?
      LVC Setting?
      For twins, I would recommend decoupling both BEC's and use an external battery
      I have built an HPR with twin Castle 240 ICE's and Neu motors and suffered from the same low speed zig-zag. It's just the quality difference between those and higher end esc's. Above half throttle they equalize reasonably well.
      TG
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • Skullcracken
        • May 2010
        • 617
        Originally posted by RaceMechaniX
        Several questions:
        Timing?
        LVC Setting?
        TG
        Yep, same settings on the software calibration. Both running on an external BEC. I also have an antenna running out of the hull.
        • expresscraft
          • Nov 2010
          • 89
          I know this is off subject,But I also want to use 2 hydro ice esc's and as I am reading this I'm wondering if there is a way to bind 2 receivers to the same transmitter?
          • Skullcracken
            • May 2010
            • 617
            Not that I know of. But even if you could, they would be likely out of sync.
            • oscarel
              • Dec 2009
              • 2127
              Sure you can bind multiple receivers to a transmitter. Not sure what would happen if you used them together.
