Resently I my castle hydra 120 esc started smoking for what I don't and they going to send me 240 free of charge .has this happen to ay one else and is this a good esc for a 2200 kv with a s240 prop on a gensis cat on 6s its a prather prop or a bit to much
castle esc
Tags: None
no I was not running that I was running stock set up on 4s with a Spartan stock prop .that's what I want to run or a 1600kv right now I'm running a finedesign nemsis 1600kv on 6s and a 645 prop on my spartan wit seaking 8hv and I'm doing low 50s to mid 50s no heating problem at allComment
I just sent in a Hydra 240lv esc, and they are replacing it with a Hydra Ice 200a HV esc. I think they are doing this as the old Hydra line has been discountinued according to Tower Hobbies. MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
A 240 lv one I hope it can take the props I got line up for it on my gensis so far I want to try s235,s240,and a s245 props I should be bout mid 60s to mid 70s with these props of the esc holds up I up graded every part of the boat to handle this speed what u guys thinkComment
Running 6s on a hydra 120 or hydra 240 (not the ice series) is a bad idea. I have done it with a new controller and cap bank, but any time it has been attempted with a used hydra or no cap bank, it doesn't last long. Only used in SAW applications with 2 passes..heat racing it would probably die even quicker due to heat buildup.Laser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
Yes, that will get the job done as its good to 8s. I still recommend an external cap bank..so does Castle if you talk to the techs! MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
They have done send it out I don't want to blow this one wat would be a safe prop to use with out harm I have a 645 sharpen and balance would that work wat prop would u recommend to use for a good cool set to do 60s don't want saw set want to be able to run couple laps wit a hop spartanComment
Could you post a pic of your boat, and the motor you are using, and KV so I can see what you have going on. Thanks, MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
.... is this a good esc for a 2200 kv with a s240 prop on a gensis cat on 6s its a prather prop or a bit to much ...
Cant post one right now I have a nemsis 1600kv from finedesigin to brand new 6400mah lipo durtrax 25c 3s upgraded to 3/16 shaft no liner and waiting for t240 to reach and only have a 645 prop right now and waiting on rather props all new cooling lines with spilters esc gets I own water and motor to no sharing water in between the two and that's wat all I have right nowComment
