I've read some on this esc. Fro what I've read, it says anything over 3s. I need an external bec. I plan on running it at 4s, so would I need an external bec? And if I do which bec is a good one? I've never had a boat before, and this is my first one. So thanks for the help
Castle hydra 120 esc??
http://www.offshoreelectrics.com/pro...004-00&cat=136
Chief -
I run 4S2P on a Mean Machine with the Castle 120 ESC with no issues. I use 4 AA Duracell batteries providing plenty of torque to the steering servo. The batteries seem to last an entire season. You can use an add addional Battery wire connector between the battery pack and the receiver, making for a quick connect and disconnect between different boats.Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)Comment
I run RX packs in my boat without BEC, and plan on using more in the future. You can get either nimh, nicad or Life, some say you could blow rx's on life but I've never had that problem on over 5 rx's (different brands). The advantage to them is it's okay if they get a little wet, even submerged, and it's one plug, not a mess of wiring to get it all hooked up. They also cost about the same or even less so that's another pro, the only con I can think of is that you have to charge it.Bling rocket 32" T600 1400kv on 6S, Twin Lynx 3126 2200kv on 4SComment
