New Turnigy marine 180
  • Rumdog
    • 6453
    Ordered a Turnigy 180 last Wednesday from HK. Pais EMS shipping, and got it today! They have made a couple changes to it from recent ones. The case is different. It has 2 tabs with holes that can be used to secure the esc. They are also now using silicone along with the rubber seal ring to make it water tight. Looks to be sealed up well, but I dont wanna find out the hard way either. I like that these Chinese companies are actually making the effort to make us boaters happy without making us wait forever to re-vamp design flaws. These esc's have been great to me in the past.
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    The really big difference is the burst current...360 amps
    Douggie
    • Alfa Spirit
      • 2131
      This one is a Hobbywing Seaking-180A ESC (Version 2.0)
      I bought two from HiModel for my twin setup catamaran, Version 2.0 is much better. HK now sale this last version
      • Rumdog
        • 6453
        My last pair, 1 Seaking, 1 Turnigy, were also V2. This one however, is a little different.
        • Alfa Spirit
          • 2131
          That' s right, I like that
          The Hobbywing Seaking 180A at HiModel is the last version. I' m not sure about Turnigy
          • m4a1usr
            Fast Electric Addict
            • 2038
            This a pic of the latest V2 Turnigy 180 wiring coming off the main pcb board. They no longer have the wires soldered thru the main board. There is a bullet or recepticle that is soldered on first and then the wire into that. And it appears that the bullet is peened onto the board prior to soldering.
            John
            Change is the one Constant
            • Alfa Spirit
              • 2131
              The Seaking 180A V2.0 from Hobbywing
              • Rumdog
                • 6453
                Yep Alfa. That looks just like mine. Tabs, and silicone.
                • fazznick
                  • Jun 2010
                  • 1
                  I just got mine today as well. Mine also has tabs and silicone. Ordered mine on sunday night and paid for ups 3 day shipping. I thought mine looked a little different than in the pics on hobbyking. Glad to see this may be a newer version.
                  • sailr
                    • Nov 2007
                    • 6927
                    Good to see the improvements. I've had good luck with my older one.
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • Himalaya
                      • Apr 2009
                      • 251
                      The silicone is better than previous version, but not sufficient. Apply more yourself, to the gap under/around the aluminum heatsink and all case joint gaps, PCB-case gaps, capacitor leads..... every gap you can think of. That will ensure your ESC to survive even if it get submerged in water, and keeps your PCB away from green copper stain.
                      • suckmywake
                        • 191
                        I see the Seaking 180a has version 2 printed on the label. Does any one have a Turnigy 180a with version 2 printed on the label? I have a 2 month old Turnigy from HK that has plastic mounting tabs and same motor leads and batt leads and silicone gasket as the v2 Seaking in above pictures but label does not say v2.
                        I will post picture when I get a chance.
                        • forescott
                          Hopelessly Addicted to RC
                          • 2686
                          Is the price the same as the older version?
                          • Flying Scotsman
                            • Jun 2007
                            • 5190
                            The new Turnigy 180 specs are the difference, as I stated, but it does not have the sealing you see on the Seaking, interesting and some have had LV cutoff problems and I note the Turnigy programmer is slightly different and they state it will not work with similar looking products and people using the Seaking programmer on Turnigy may have a programming issue.
                            Douggie
                            • Rumdog
                              • 6453
                              My new one is The Turnigy. It has the sealing, and bolt holes. It does not say version2. The program card is the same for the seaking and turnigy. They are the exact same controllers. The only incorrect prog. box, is the one for land based esc, which I'm told you can order a face plate for. In my twin cat, one esc was a Turnigy 180, the other was a Seaking. They performed exactly the same. I don't think they are selling it as a new version. V2 has been out for several months now. Seems they are just making a few necessary adjustments along the way.
