Turnigy 180A ESC Issues
  • mschaffer66
    • Jan 2010
    • 335
    I just bought a pair of these, threw one in my Supercat, ran for a few minutes, peaked at 77A and put it away for the day. Was running on 4S.
    Then today when I pulled it out to go run again I plug it up and all it does is beep occaisonally, no motor, no servo. Nothing. I try to reprogram etc...nothing. Then by accident I plug an RX pack into my RX to test the receiver and suddenly the ESC arms, RX comes on, servo and motor works...
    Does that mean the internal BEC dead?
  • Rumdog
    • 6453
    Yes. Unplug the red wire anyhow.
    • mschaffer66
      • Jan 2010
      • 335
      I know these things are cheap as sh... but is that a common failure with them? I'd prefer to not run an RX pack, but oh well if I do I do no biggie.
      • Rumdog
        • 6453
        Actually, they're inexpensive, not cheap. IMO they are one of the best lv esc's on the market. Not sure why your bec failed. I NEVER run the bec on any boat over 3s. A R/X pack or ubec is the best way to go.
        • mschaffer66
          • Jan 2010
          • 335
          You are right, not cheap, inexpensive. Maybe I just got one with a bum BEC. I may just get one of those little castle BEC's and not run the rx pack cost is about the same and then I don't have to have yet another battery to keep charged.
          • MaxCorvette
            • Feb 2010
            • 12
            I also have 2 of these esc's, very nice but I blew one of the becs while just bench testing.
            Steering servo wasn't even connected to the rudder.
            I think we need to use these with rx batt or Ubec to be safe..
            Marcel
            • LiPo Power
              DJI Drone Advanced Pilot
              • May 2009
              • 3186
              Same here..... My BEC went wheeeeee....
              So on the new one I will use external BEC....
              Robert
              Canada
              • mschaffer66
                • Jan 2010
                • 335
                I just went and got a castle bec today I will run it again
                • rchippie
                  • Jan 2010
                  • 567
                  My bec died on my Turnigy 120. I just simply unplugged the red wire run a reciver pack.
                  • sailr
                    • Nov 2007
                    • 6927
                    Same problem here. I've had a couple blow the BEC. Not sure why. Seems to be a weak point in the ESC.
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • bustitup
                      • Aug 2008
                      • 3071
                      but you need to put the red wire back on when using the program box right?
                      • rchippie
                        • Jan 2010
                        • 567
                        I never had to re program mine after the initial setup. So im not sure.
                        • BakedMopar
                          No Mo Slipah
                          • Sep 2009
                          • 1679
                          No you can plug in you external pack into the box to power it up.
