ESC with datalogging of BEC current
  • NativePaul
    Greased Weasel
    • 2760
    Hi, I want to measure the current draw of my servos when in use, so that I can replicate those loads on the bench for some servo testing.
    Do any of you know of a brushless ESC that has datalogging that includes BEC current? that seems like it would be the easiest, take the loaded BEC current, disconnect the servo and take the RX current, subtract that from the BEWC current and that's the servo current,
    Or failing that a tiny low current DC datalogger that I can wire the servo into.
  • Xrayted
    • Jan 2023
    • 274
    My Castle Mamba Monster X8S has full data logging including the BEC V. You can see the real time data of multiple parameters at any point during the run if you load the file into the Castle datalog reader per the attached image. My ESC was converted to water cooling using a Stumpfab water cooling plate because the only Castle water cooled version at the time was the much larger XLX2 which was overkill for my mono
    Castle now has a watercooled X8S ready to go without modification. https://www.castlecreations.com/en/m...ec-010-0175-00
