Hk4035 turnigy monster toasted:(
  • JMSCARD
    • Mar 2010
    • 3444
    So I just got back from the lake and I had another bad day... Was running my 44" aeromarine team America 44" cat with a scorpion hk4035/800 and a new turnigy monster 2000.... Ran one set of batts through the boat in 10s1p format 30c batts 5300mah on a x455 prop.... Motor came in at 155 degrees and batts were 135, and esc was 125.... Went out 20 minutes later after cool down and ran 10s2p 7400 mah 20c batts and got 2 minutes into the run and she shutdown... Opened the hatch to see the point where the motor wires were soldered to the esc came unsoldered and looks as though it all happened because the scorpion outrunners motor wires had shorted out... Checked temps and motor was 182 esc was 140, batts were 95, even though they say the scorpions can "take the heat" looks like the motor wires themselves can't they shorted together in a spot real close to the can....looking at the esc looks like a "fet" cracked? Don't know if the esc is repairable or the motor is? Motor still has normal cogging but sounds like a slight rubbing noise in one spot..... What if anything should I do? I will post pics tommorrow when I get to work.... Makes me upset that the motor wires shorted.... Boat was running very well too.... Obviously though it was a little to hot of a setup....
  • RIPFENCE
    • Sep 2009
    • 1332
    wow man you have had some bad luck lately hope things turn around during this new england boating season
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
    • NativePaul
      Greased Weasel
      • 2761
      The motor will be repairable, when you take the endbell off an outrunner thet look like brushed motors only without the brushes, and are just as easily rewound.
      • Mel279
        • Dec 2008
        • 857
        I also have the same problem with my scorpion motor, I toast it and I send it back to the manufacturer, and I was offered 50% off of their motor since my motor is expensive to be repaired. I would think this motor is not suitable for inboard setup, and your esc is fine and don't bother to run that motor again, if not u surely toast it.
        • JMSCARD
          • Mar 2010
          • 3444
          Still think the esc is fine mel? notice the esc fet looks cracked.... does anyone fix these ?
          What do the rest of you think I was pulling for amps on 10s with a x455 octura on this 800kv outrunner?? Should I talk to scorpion on this one?
          • Mel279
            • Dec 2008
            • 857
            So sorry, I thought your esc survive, but anyway u can send it back to the manufacturer since scorpion motor has 2 year warranty provided that u attach the original receipt of purchase.
            • JMSCARD
              • Mar 2010
              • 3444
              Send what back to the manufacturer? the esc or the motor? I take it scoropion won't do anything about their motor taking out my esc?
              • JMSCARD
                • Mar 2010
                • 3444
                "The stators are epoxy coated to prevent shorts, and are wound with wire that is rated at 180 degrees C (356 F). The magnets used in Scorpion Motors are N-50EH style, which are rated for operation at 200 degrees C (392 F), making a motor that is virtually impossible to burn up in normal use."
                This is off of Scorpions website.... not impressed.
                • Dragonturbo3
                  • Jul 2007
                  • 63
                  If you can get the damaged FET off and find the part number (on one of the good FET's) you can order them. I did this on a Traxxas EVX Marine. It was a pain but it did work.
                  • JMSCARD
                    • Mar 2010
                    • 3444
                    If the esc is repairable does anyone know of someone who does such a thing... I have a hard enough time soldering bullets never the less fets?
                    • Mel279
                      • Dec 2008
                      • 857
                      Just the motor, they'll replace it even it bust up, just like I said before if u still have the receipt, or if u don't have it, they offer you 50% off the retail price.
                      • Mel279
                        • Dec 2008
                        • 857
                        Do u know any website that sell FET online?
                        • K.R.Joye
                          • Feb 2010
                          • 1045
                          That a bummer Jim, I would definately take advantage of the warranties on both items. Let us know how the Monster warrantee experience works out. BTW was it coated for water-resistance?
                          Sound like you were doing everything right.
                          ~~~~~~~~`Mach 5 racing'~~~~~~~~~~~~
                          ****2008/9 MMEU LSO, 2008 LSH CHAMP****
                          ~~~~~~~70 MPH Club Member!~~~~~~~~~
                          • JMSCARD
                            • Mar 2010
                            • 3444
                            No it wasn't coated..... :) good thing as it would probably void the warranty.... This was in your old hull mr joyle:) she stays dry too.... Was running great when it all happened.... What a nice handling cat with those linked trim tabs.... And the scorpion was working great getting th hull motivated... I would say on the 10s2p setup I was seeing mid to high 50's...
                            • ozzie-crawl
                              • Sep 2008
                              • 2865
                              had the same thing with a scorpion motor,it took out my esc as well, motor was replaced under warranty.
