Wow thanks! I was wondering what the exposed tab was for on the left side of the ESC board was for. I found a great pic of the EZ run with a on/off switch if anyone else is interested. The middle jumper apparently powers an optional fan. Right jumper is the rx leads.
Anyone have anything bad to say about the Turnigy 180 Controller?
180 Issue
Just thought I would add this. I ran a 180 at 135Amps on 6s and it did not get hot. After the first run I changed to a smaller prop to draw 90Amps. I plugged everything in and it was fine. Put the boat in the water and hit the throttle - nothing - no servo no throttle.
I have since done a bunch of trouble shooting including eliminating the BEC from the circuit and the ESC still does not work. It beeps every 2 seconds when I plug it in but it will not arm.
I am just about ready to send it back...unless someone here can help...
MarsComment
esc
Did you accidentally adjust the throttle trim... If it doesn't read that its at neutral throttle the esc won't arm.... If all else fails start over with programing the esc to your radio.... before programming to your radio make sure throttle trim is centered....Comment
Program card will not work...
Thanks JMSCard - I just tried to plug the ESC into the program card and the card gets no power. I plugged the ESC into the card and used a separate power source (6V battery) and the program card still does not come on...
It is so frustrating knowing that the ESC is in there somewhere as it understands that it is not getting a good throttle reading but it will not react to anything...
Mars
I am responding on my iPhone or I would get the "manual" program instructions for you.... Do u still have the instructions that came with the turnigy? Try using those instructions as maybe your program box is smoked... I think u connect the battery with full throttle applied to enter program mode.... Anyhow try the manual programming....
Also make sure u r putting the rec battery in the right input of the program box as both that and the esc input are the same size.... Just making sure you r trying everything....Comment
Card plug Correct
I am sure I put the esc and battery plug into the proper slots on the card. I tried to enter program mode on the esc but it just beeps as it always does. Keep the ideas coming as I want to try everything before I wait for who knows how long for another esc.
As a last ditch effort I am going to try a different rx...
Mars
Also be sure you didnt run another model etc w/ the TX and put the throttle back to normal. It must be reverse for the Turnigys to work.... and I cant think of anything else obvious right now....Comment
Isn't that for Futabas only? Mines arms and runs with it on normal with my Tactic and M8.If all of your wishes are granted, many of your dreams will be destroyed!Comment
$33 Later...
I sent the ESC back to HC for $33.
I will keep you posted on the status. About 2 years ago I sent a Lipo back to HC and they replaced it. I am hoping for the same treatment here as I never ran this thing outside of its specs.
If they do replace it I will make sure I do not use the BEC but add an rx pack to my boat.
Thanks for all the help,
MarsComment
Mars
How come shipping is so expensive? cost me $12 for the last item returned and it was large 6 cell lipo. (no express mail though)Comment
How did you send it to get it so cheap!? I got a DOA $50 power supply from HK and it was gonna cost $40 to ship it back. I threw it in the trash!Mini Cat Racing USA
I just got some more lipos and another monster 200 turnigy from hc..... 7 days after order was in my hands..... Like someone else posted they moved there warehouses and it delayed stuff.... I think I've had 30 transactions with hc.... Not once have I had a bad experience.... I also run my turnigy 180's on 6s just fine..... I run one in my mean machine with a 1515 1.5y on 6s and I'm actually going to run one in my drifter l with a 9xl on 5s and 6s.... The drifter has a hydra 120 I don't want to kill so I'm gonna use my tried and true turnigy 180's.... Great esc....And easy to program even without a program card.... Tho I do have a program card sometimes I forget it at home..... Well I better go back to installing the kayak racks on the suv..... Boating season is here in Vermont:)SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
