First, no I don't work for them or affiliated with them or anything. I just got this new charger and have been playing with it. Really nice piece of equipment. I can parallel charge up to 6 batteries and balance them while charging. Lot's of power as you will see in the video.
This is what I bought. You can get it much cheaper on ebay.
The only thing I needed was to convert the connectors from deans to 5.5mm. I could have done it myself, but I found a place that had them made up for cheap so I just ordered a bunch of them.
Things I like about the charger
1. High Power
2. Simple to use.
3. Does not Need a PC, but you can hook one up and see a lot.
4. Nice ready made set to charge 6 batteries at a time.
5. Balances while you charge. (It did a perfect job of it for me).
Things I have found that I am do not like or have not figured out how to do(learning curve).
1. Is there a way to parallel charge without hooking up for balancing?
2. The 2s hyperion plugs don't work with the balancer. This is because the 2s plugs on the hyperion are 4s tap plugs, I have to get adapters. Not really the fault of the charger.
3. I noticed tonight that if I pick to charge "3c" to let the charger decide on the amperage, it is very conservative. If I manually put in the amps then away it goes and charges fast.
More to come...
1. High Power
2. Simple to use.
More to come...
