Safe, cheap, easy-to-get protective covers for 5.5mm bullets on batteries?
  • desmobob
    • Sep 2011
    • 170
    What are you guys using?
  • ray schrauwen
    • 9471
    I just use shrink wrap. Typically most people have batteries wired red hot female. Female positive lead and male negative. If you use a few layers of heat shrink and overhang it about 1mm over the lip and cut the negative 1/2" shorter it's pretty much impossible for them to touch accidentally. You would have to try to plug them in and to end on purpose to ever have a problem.
    2 or 3 layers works well for me.
    Nortavlag Bulc
    • NativePaul
      Greased Weasel
      • 2759
      I use neon yellow 6mm/8mm silicone tube, like water line but bigger.
      I bought 2m of it many years ago for under ?7 and I will be surprised if it doesn't see me out.
      • lohring
        • Jun 2011
        • 182
        I use McMaster-Carr plastic caps. The 5/16 x 3/4 size still works on 8 mm connectors as well as smaller ones. See https://www.mcmaster.com/9753k17/
        Lohring Miller
        • desmobob
          • Sep 2011
          • 170
          Thanks for the great tips, folks. I appreciate it.
          • T.S.Davis
            • 6221
            Me too. I always have it kicking around. I lose them so bad I can just snip another off the length. Works well on 6mm connectors but is a little tight. Horrible on 8mm.
            Another option is screw caps. I usually take a connector into the hardware store and sift through the different sizes until I find one that slips on nice. Another great option is surgical tubing. Cut a piece to length. Fits multiple sizes. With 5.5 you could probably slide it right up onto your shrink wrap.
            Noisy person
            • denboy01
              • Sep 2007
              • 59
              Rubber end caps used for the carbon rods on stunt kites can be bought in various sizes too
              • desmobob
                • Sep 2011
                • 170
                I ordered some 6mm ID/8mm OD silicone tubing in bright yellow. That ought to do the trick for me...
                Thanks again,
                Bob
                • metrorubber
                  • Sep 2023
                  • 1
                  you can try pvc heat shrink sleeves.
                  neoprene-sheeting
