Salt Water bath?
  • ray schrauwen
    • 9471
    Salt Water bath?
    Lots of packs to euthanize and I am curious as to how much salt to use to kill some packs. How many packs can I soak in this one bath and how do you dispose of the water after?
    Any other info is appreciated. I use my discharger and ISDT Q8 charger to bring them down to zero. The charger has a neat "KILL" funciton.
  • Bande1
    • Mar 2023
    • 684
    I always just charge them fully then put in a bucket of diesel soaked ammonium nitrate use for target practice.
    • ray schrauwen
      • 9471
      LOL, Thanks for making me laugh
      • TRUCKPULL
        • 2971
        Ray cut the power wires off of them also the balance wires. (one at a time)
        If you don't have a use for them - give them to me.
        Cover with water and about 1/2 cup of salt, let sit for a week the into the garbage.
        Larry
        • Panchothedog
          • Oct 2015
          • 174
          Somewhere I read a pound of salt for 2 to 2&1/2 gallons of water. DO as Truckpull says, and cut the wires off. I have done as many as 3 at a time, in a 5 gallon paint bucket. If you buy the salt " Mortons " the containers at the
          supermarket are 1 lb. I flush the used water down the toilet.
          • tbonemcniel
            • Sep 2020
            • 296
            I just hook up a automotive headlight bulb to the mains, and go leave it in the driveway on the concrete for a little while. Drains them right down. Haven't had one do anything during that other than puff and swell a lot.
            • Xrayted
              • Jan 2023
              • 273
              That’s what I do as well. I use two old-fashioned automotive headlight bulbs wired in series. That will drain them down to zero, and the packs will puff right as they hit that zero mark, but they have no energy left and are inert at this point so nothing to worry about with the puffing
              The salt water bath is actually a misused myth that has been passed around for years. If you read the document where that concept originated from, the instructions are to put them in the salt water bath only AFTER they have been fully drained.
              Placing Lipo‘s in a salt water bath causes the cells tab connecting them together to be eroded away relatively quickly, meaning you may or may not get a voltage reading on the mains anymore, however, the cells still have plenty of energy left in them and are not inert from the salt water bath alone
              • jkflow
                • Aug 2021
                • 329
                Saltwater is an old thing that just won't die. It's silly to waste the salt.
                Discharge with a lightbulb or load, as per above, and just throw them away. I always twist the leads together once they are empty.
                Saltwater is as useful as blinker fluid.
                • ray schrauwen
                  • 9471
                  Lol.... lots of info here, thanks!
                  • TRUCKPULL
                    • 2971
                    Run them down with your discharger, Cut the wires off, if you want proof that the salt water works.
                    Slice the coating on the cells. so that the foil on each is split open, to let the water into the cells. When the saltwater soaks in, they will start to bubble.
                    This is killing any type of power left in the cells.
                    Let them sit for a week.
                    To do multiple cells, use 1/2 cup.
                    Larry
                    • jkflow
                      • Aug 2021
                      • 329
                      Slicing alone will do that, no saltwater needed. Not needed if you discharge them to zero. Waste of time and effort but it will make bubbles.
                      • ray schrauwen
                        • 9471
                        Advice taken..
                        Q: Eight year old Revo cells, 6S Puffed, 6.6mO per cell, Should I kill them?
                        • Panther6834
                          • Apr 2020
                          • 708
                          Advice taken..
                          How badly? Photo?
                          • ray schrauwen
                            • 9471
                            Originally posted by Panther6834
                            How badly? Photo?
                            I'm destroying them, one down for now. Too puffy. I'll try to get a pic before I kill the second pack.
                            • Panther6834
                              • Apr 2020
                              • 708
                              If they're not overly-puffy...particularly 2S & 3S...I usually hold onto them, for testing new ESCs & motors when installing them. But, those ones never leave the house - they stay right near my RC workstation.
