Battery recommendations
  • waterworld motorsports
    • Jan 2021
    • 10
    I just purchased a MHz 138 I?ve got two to 5680 motors an ztw 300 esc looking to go 8s or 12s looked at the true spec dv22.2 6500mah 120amps/75c with g10 plates not necessarily looking to race trying for a good speed are these any good for the price an will they last any info or recommendations appreciated thanks
  • koen
    • Mar 2020
    • 358
    It's serious power for a serious boat ,look at steffansliposhop.de or hobbyking graphene panther
      No one can really help the OP without more information.
      - what is the Kv of the motors?
      - is it 8S or 12S? You can’t have both.
      - what is ?a good speed??
      - what kind of run time will you expect?
      - why do you need armored packs?
      - what is your battery budget?
        • Jan 2021
        • 10
        The motors are 800kv a good speed close to 100 as far as run time 10-15 mins an for the armored part not sure what that is an for my budget don’t wanna spend max amp prices but something reasonable thanks
        • fweasel
          master of some
          • Jul 2016
          • 4291
          No one should ever spend Maxx Amp prices... the most over priced, over rated, poorly tested lipo batteries made.
          Vac-U-Tug Jr (13mph)
          • EddieM41
            • Aug 2018
            • 192
            Made that mistake once (Maxx Amps)....never again!!!
              • Jan 2021
              • 10
              What batteries do you have good experience with
                • Jan 2021
                • 10
                What type of batteries do you use
                • Peter A
                  • Sep 2012
                  • 1487
                  Graphene panthers.
                  • T.S.Davis
                    • 6220
                    I've moved to HRB.
                    Noisy person
                    • HTVboats
                      • Jun 2011
                      • 803
                      Roaring Top, look at the record book. Not expensive and weight per ma is one thing I look for.
                      Mic
                      Mic Halbrehder
                      IMPBA 8656
                      NAMBA 1414
                      • Ken Haines
                        Racer
                        • Jul 2007
                        • 647
                        HRB - 100c Graphine
                        TenShock Brushless / Pro Marine
                        INSANE Boats / Rico Racing/ Castle Creations
                        2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
                        • RaceMechaniX
                          • Sep 2007
                          • 2831
                          There are a couple good brands for boating needs.
                          If you are running 2P per motor the HobbyKing Graphenes are hard to beat for performance and value. The solder tabs are the weak point in these batteries so paralleling them reduces the current draw per pack. You can use two 3000mAh packs in parallel to get 6000mAh. Their chemistry is very stable and I have not seen much degradation over time.
                          If you are running 1P I would recommend the RoaringTop 80C cells or Dinogy Graphene 2.0 70C cells. Both these companies are run my model boaters and the cells have good construction and chemistry.
                          Since you are running a twin cat you cannot likely fit 2P of cells per motor are the higher cell counts so the RT's or Dinogy's would be my recommendation.
                          Tyler Garrard
                          NAMBA 639/IMPBA 20525
                          T-Hydro @ 142.94mph former WR
