Parallel or Series first?
  • jingalls007
    • 1015
    Just want some ideas on personal preference. Thx!
  • photohoward1
    • 1611
    That's apples and oranges. One is increasing voltage (series) one is increasing capacity (parallel)
    • Panther6834
      • Apr 2020
      • 708
      I know what you mean...akin to asking whether a Toyota, or a Cessna, is better.
      ~ More peace, love, laughter, & kindness would make the world a MUCH better place
      • jingalls007
        • 1015
        I should have clarified..
        I?ve got 4, 6s packs @ 10,000 mah each. I?ll be running 44v for a total of 20,000 mah.
        Should I parallel the packs first for 6s, 20,000 mah then series for 12s, 20,000 mah or should I series first then parallel?
        Make sense? I can draw a diagram if you?re better with pictures.
        • fweasel
          master of some
          • Jul 2016
          • 4291
          I would do it whatever method results in the least amount of additional wire. How the packs are packaged inside the hull probably has more to do with the solution than anything else.
          Vac-U-Tug Jr (13mph)
          • jingalls007
            • 1015
            That makes sense. I haven?t run a 4p setup before so I wanted to make sure I wasn?t making a mistake. Thanks doode!
            • Jesse J
              scale FE racer
              • Aug 2008
              • 7121
              I always do series then parallel. I did make a 4p adapter.. once. I agree with Ryan, least wire = lesser resistance= mo bettah
              "Look good doin' it"
              See the fleet
