Measuring resistance
  • Crash
    • Oct 2015
    • 313
    is there a way to measure the resistance in the connections between your wires in your lipos in your motor and your ESC Etc
    I'm getting Heat at my connections over a hundred and fifty degrees Fahrenheit
  • Prodrvr
    • Jul 2015
    • 701
    The wire resistance between the battery and esc is insignificant. What connectors are you using for battery to esc connection? Esc to motor?
    • Crash
      • Oct 2015
      • 313
      6.5 mm
      • TRUCKPULL
        • 2975
        What solder are you using?
        Larry
        • Prodrvr
          • Jul 2015
          • 701
          I use 6mm from esc to motor, 7mm from batt to esc, all soldered with lead free 4% silver solder. Haven't had any heat issues on the connectors. How's the temps on the esc, motor, battery?
          • Crash
            • Oct 2015
            • 313
            Larry
            40 tin 60 lead w flux
            • Crash
              • Oct 2015
              • 313
              the motor, batteries, ESC are not hot. 120 to 135F
              • StevenBryant
                • Nov 2012
                • 359
                Crash you are running connectors rated at 200 amps in a setup pulling 250amps. Use 8mm castle connectors rated at 300amps or Lehner 6mm connectors rated at 400amps.
                An electric current flows when electrons move through a conductor, such as a metal wire. The moving electrons can collide with the ions in the metal. ... As the temperature increases, the metal ions vibrate more. There are more collisions with the electrons and so the resistance increases
                Resistance has a direct relationship to the temperature of the connectors, at ambient temperature the connectors will show a lower resistance than when the connectors start to heat up.
                • Crash
                  • Oct 2015
                  • 313
                  I took the 6200 watt motor out, it was pulling 255 amps.
                  I put a 4200 watt motor in and ran it for a test lap at pond and checked temps and the damn wires are the hot spot again. if its not poor soldering job it must be the connectors..
                  • TRUCKPULL
                    • 2975
                    60/40 is not the best for electronics.
                    This is the stuff that Castle uses
                    Kester -SN96.5AG03CU.5 2.2%
                    Larry
                    • ray schrauwen
                      • 9475
                      Larry
                      That stuff is the shiznits! Thanks for the solder Larry!
                      Nortavlag Bulc
                      • goodone963
                        • Mar 2019
                        • 1
                        What resistor are you using?
